I'm experimenting with exporting Test Plans (and associated items like Test Runs, Test Cases, etc) into Word using a custom template.
One of the things I'm trying to do is export a Test Cycle.
Within a given Test Plan, there are three buttons I can choose to show me different aspects of the Plan: 'Overview,' 'Test Cases,' & 'Test Runs.' So far so good.
When I Export from the 'Overview,' all I get in the generated Word doc is information directly related to the 'Test Plan' item itself - that is, I
don't get output from the 'Test Cycles' and 'Test Runs' that are contained within the 'Test Plan.' Now, this
might be correct behaviour but I had expected that the whole of my Test Plan (that is, the 'Test Plan' overview, its associated 'Test Cycles,' and the cycles' 'Test Runs') would all have come out in the exported doc.
Am I doing something wrong? Or should I not expect to get the whole Test Plan in one go?Moving on ... if I push the 'Test Runs' button, I see a list of the Test Runs in whichever Test Cycle I've got selected. If I export to Word from there, I get the info from the Test Runs involved. BUT, what I DON'T see anywhere is any of the details of the Test Cycle, other than its Name in the <<contextName>> field. That is, the Rich Text 'Description' field of the Test Cycle does not get exported out as I had expected.
This seems odd to me. My Custom Template definitely does have the <<TemplateStart:TSTCY>> and <<TemplateEnd:TSTCY>> tags and all the tags from the default template in between them so I think I should be expecting to get all the Test Cycle details exported. Again, am I doing something wrongly?
Ian Webb
Enphase Energy, Inc.
