list view columns not updated after item update
  • 1.  list view columns not updated after item update
    Posted 12-04-2019 10:12
    When I make updates to an itemtype to add new fields, they don't show up in the end user's list view because they have previously adjusted the list view for that item type. How do we reset the list view for an itemtype to match the updated list view configuration in the admin section?
    Rafael Medina
    ON Semiconductor
  • 2.  RE: list view columns not updated after item update
    Posted 12-04-2019 13:52
    Rafael:
    After you add the new fields to the item-type do you then go got the Views > Project List View and then drag-drop the fields to the "Visible fields" area?
  • 3.  RE: list view columns not updated after item update
    Posted 12-05-2019 12:18
    Hi Chloe,
    I already updated the default views for the itemtype, but for any user that had local adjusted the list view already, there doesn't seem to be any way to reset the view to the configured default.
    It is common to hide or show columns for one reason or another when viewing data, but after doing so, users will never see updates to the default view, and have no convenient way of resetting to the default even if no itemtype changes have been made.
    Rafael Medina
    ON Semiconductor
