Get a list of the latest test runs for a set of test cases
  • 1.  Get a list of the latest test runs for a set of test cases
    Posted 11-25-2019 02:06
    Edited by Jonas LastName 11-25-2019 02:06
    I'm looking into how we can improve our reporting of test case results on Jama 8.14.1. Most of the things have been sorted out, but there is still an issue that I can't seem to find a solution for.
    We have a set of hundreds of test cases (which is why I would like to find a good way to solve this so that we get rid of some time-consuming work). For each test case I would like to get the the last executed test run in a List View. This List View I then need to be able to export using a Word template.
    I have seen that if I paste all test runs IDs (separated by spaces) into a List View of all existing test runs, this filters them out. So an acceptable solution is to find a way to get the test run IDs for the test runs I'm looking for. I tried this from the List View of test cases test cases, but it was not possible since there is no option to show the last executed test run ID, only the test case status for the last executed test run.
    Is this something that is possible? I'm looking for a non-script solution.
    Jonas Granquist
    Jonas Granquist
  • 2.  RE: Get a list of the latest test runs for a set of test cases
    Posted 11-26-2019 02:40
    Hi Jonas,
    I was faced with the same issue and unfortunately, I was only able to do this with a velocity report.
    If you are interested in this report, I can provide you some code sample (honestly it is not that complicated to adapt)- just let me know.
    Sebastian
    Requirements Engineer
    Sick AG
  • 3.  RE: Get a list of the latest test runs for a set of test cases
    Posted 11-26-2019 22:05
    Edited by Jonas Granquist 11-26-2019 22:05
    Hi Sebastian,
    I would appreciate a code sample very much! Haven't tried out the Velocity reports (yet) but they seem to be very powerful.
    Jonas Granquist
  • 4.  RE: Get a list of the latest test runs for a set of test cases
    Posted 11-27-2019 04:20
    I would be interested too.
    Sven Schmidberger
    Irdeto
  • 5.  RE: Get a list of the latest test runs for a set of test cases
    Posted 11-27-2019 06:48
      |   view attached
    Hi Guys,
    I tried to upload a generic velocity report (you just have to rename it to xyz.vm).
    This report is context based, thus it works best for filters- e.g. all requirements (not the testcases) which you want the test coverage for.
    The report will then get the last modified testrun for all related testcases and display the state (with hyperlinks to the items).
    In the code, the only thing you have to do is add the url of your jama instance (relatively at the beginning of the code) and enable it in Jama.
    I hope this helps a bit- for us it was the only way to get a feeling of "have we finished yet?" ;)
    Here is the code (in case the upload did not work)
    ############################################################################################################################################################## Name : Testplan coverage#### description : for each item (requirement) in the documentList, prints the##               verifying Test Cases and the last executed related Test Run. ##               To be used to check for requirement coverage.##               To be used as context-sensitive report (uses documentList)##  #### parameters  : sReportTitle (String; String added to title)## no effect: sTestplanFilterVariant (String; only use Testplans that include the given string, like PRIME)## no effect: bIncludeInternalTestplans (boolean; if TRUE also include Testplans that include INTERNAL string)################################################################################## MODIFICATION HISTORY## Date        Version  Author            Comment## 2019-10-08  V1.1      Sebastian Merz    use tables in tables in tables################################################################################
    ##############        #### MACROS ####        ###############macro(additemURLtoHTMLblank $flag $jamaurl $itemid $projectid $text) #if($flag == true) <a href="http://$jamaurl/jama/perspective.req#/items/$itemid?projectId=$projectid" target="_blank">$text</a> #else $text #end#end
    #macro(addURLtoHTMLblank $flag $url $text) #if($flag == true) <a href="$url" target="_blank">$text</a> #else $text #end#end########################
    #set($docDao = $applicationContext.getBean("documentDao"))#set($relDao = $applicationContext.getBean("relationshipDao"))#set($testRunDao = $applicationContext.getBean("testRunDao"))#set($userDao = $applicationContext.getBean("userDao"))
    #set($securityContextHolder = $applicationContext.getClassLoader().loadClass("org.springframework.security.core.context.SecurityContextHolder"))#set($actualUser = $userDao.getUserByUserName($securityContextHolder.getContext().getAuthentication().getPrincipal().Username).getFullName())
    ## add your jama URL here#set($jamaurl = "yourjama.company.net")#set($testrunstatushelpurl = "http://yourjama.company.net/jama/help/ah/en/test/test-runs/test-run-status.html")
    ## sTestplanFilterVariant shall be defined in the report UI. Otherwise use empty string as default (for all testplans)#if(!$sTestplanFilterVariant) #set($sTestplanFilterVariant = "")#end
    ## bIncludeInternalTestplans shall be defined in the report UI. Otherwise use 0 as default.#if($bIncludeInternalTestplans) #set($sInternalTestplan = "INTERNAL")#else #set($bIncludeInternalTestplans = false) #set($sInternalTestplan = "")#end
    ## bAddURL shall be defined in the Report GUI. Otherwise use 1 as default#if(!$bAddURL) #set($bAddURL = true)#end
    ## bStatistics shall be defined in the Report GUI. Otherwise use 1 as default#if(!$bStatistics) #set($bStatistics = true)#end
    ## bNoDetailedList shall be defined in the Report GUI. Otherwise use 0 as default#if(!$bNoDetailedList) #set($bNoDetailedList = false)#end
    ## sReportTitle shall be defined in the Report GUI. Otherwise use an empty string as default#if(!$sReportTitle) #set($sReportTitle = "")#end
    #set($doctypeFirstElement = $documentList[0].document.getDocumentType())#if($doctypeFirstElement.documentTypeKey == "SET" || $doctypeFirstElement.documentTypeKey == "CMP" || $doctypeFirstElement.documentTypeKey == "FLD") #set($sReportTitle = "$documentList[0].document.name ($documentList[0].document.documentKey) : $sReportTitle")#end
    <html><head><style>a:link { color: black;  background-color: transparent;  text-decoration: none;}a:visited { color: black; background-color: transparent; text-decoration: none;}
    a:hover { color: red; background-color: transparent; text-decoration: none;}
    a:active { color: yellow; background-color: transparent; text-decoration: none;}</style> </head><body>
    <h1>Report on Requirement - Test Case - Test Run Coverage</h1><h1>$sReportTitle</h1>
    #if($bNoDetailedList == false) <h2>Detailed List</h2> <table border="1" cellpadding="1" cellspacing="0" style="border-collapse:collapse"> <thead> <th>Requirement</th> <th>Suspect?</th> <th>Test Cases</th> <th>Suspect?</th> <th>Test Run Results</th> <th>Pass with Error?</th> <th>Test Cycle</th> <th>Test Plan</th> </thead> <tbody>#end
    #set($nReq = 0)#set($nReqNoTestCase = 0)#set($nReqWithTestCaseNoTestRun = 0)#set($nReqWithTestCaseWithBlockedTestRun = 0)#set($nReqWithTestCaseWithFailedTestRun = 0)#set($nReqWithTestCaseWithPassedTestRun = 0)#set($nReqWithTestCaseWithNotRunOrInprogressTestRun = 0)#set($numTestCases = 0)
    ## Loop over all given items (should be requirements)#foreach($vdoc in $documentList) #set($doctype = $vdoc.document.getDocumentType()) #if($bNoDetailedList == false) <tr> <td>#additemURLtoHTMLblank($bAddURL $jamaurl $vdoc.document.id $projectid $vdoc.document.documentKey) </td> #end #set($cellcontent = "") #set($sTestCase = "") #set($bgcolortable1 = "white") #set($bAnyTestCaseWithoutTestRun = false) #set($bFirstTestCaseLoop = true) #set($bTestCaseExisting = false) ## Marker to detect if line feed for table must be made #set($oFirstTestForReq = true) ## *********************************************** ## Loop over each downstream from the current item ## *********************************************** #foreach($leaf in $relDao.getDownstreamDocumentIds($vdoc.document.id)) #if($docDao.getDocument($leaf).getActive() == true) #set($doctype = $docDao.getDocument($leaf).getDocumentType()) ## Only select the related Verification items (TEST_CASE type) #if($doctype.getCategory() == "TEST_CASE") #set($numTestCases = $numTestCases + 1) ## mark that a test for the item exists #set($bTestCaseExisting = true) ## This block checks if more tests for the same requirement come and adds a needed empty table cell #if ($oFirstTestForReq == true) #set($oFirstTestForReq = false) #else ## Add empty table row cell <td></td> #end
    ## ***************************************************************** ##                Check if the Test case is suspect ## ***************************************************************** #set($bSuspect = $relDao.getRelationshipBetweenDocuments($vdoc.document.id, $docDao.getDocument($leaf).getId() ).getSuspect() ) #if($bSuspect == true) #set($bgcolor = "red") <td bgcolor="$bgcolor">suspect</td> #else #set($bgcolor = "white") <td></td> #end #set($sTestCase = "#additemURLtoHTMLblank($bAddURL $jamaurl $docDao.getDocument($leaf).getId() $projectid $docDao.getDocument($leaf).getDocumentKey())")
    <td bgcolor="$bgcolor">$sTestCase</td>
    ## ********************************************** ## Now find the last test run for this test case! ## ********************************************** #set($bFirst = true) ## Reset temp variables #if($bFirstTestCaseLoop == true) #set($bAnyTestCaseWithBlockedTestRun = false) #set($bAnyTestCaseWithFailedTestRun = false) #set($bAnyTestCaseWithPassedTestRun = false) #set($bAnyTestCaseWithNotRunOrInprogressTestRun = false) #set($bFirstTestCaseLoop = false) #end #set($latestTestRunId = "") ##set($cellcontentAllTestRuns = "") #set($cellcontentLastTestRun = "") ## Loop over all test runs for the test case #foreach ($testRunLoop in $testRunDao.getTestRunIdsForTestCases([$mathTool.toInteger($leaf)])) #set($testRun = $testRunDao.getTestRun($testRunLoop)) #if($testRun.getActive() == true) #if($bFirst == true) #set($latestTestRunId = $testRun.id) #set($bFirst = false) #else #if($comparisonDateTool.difference($testRunDao.getTestRun($latestTestRunId).getModifiedDate(), $testRun.getModifiedDate()).getSeconds() > 0) ## case newer test run #set($latestTestRunId = $testRun.id) #end #set($n = $docDao.getDocument($leaf).getDocumentKey().length()) ##foreach($i in [1..$n]) ## #set($cellcontentAllTestRuns = "$cellcontentAllTestRuns&nbsp;") ##end #end #if($testRun.getTestRunStatus() == "BLOCKED") #set($bAnyTestCaseWithBlockedTestRun = true) #elseif($testRun.getTestRunStatus() == "FAILED") #set($bAnyTestCaseWithFailedTestRun = true) #elseif($testRun.getTestRunStatus() == "PASSED") #set($bAnyTestCaseWithPassedTestRun = true) #else ## either INPROGRESS or NOT_RUN #set($bAnyTestCaseWithNotRunOrInprogressTestRun = true) #end #end #end ##/ Testrun loop ## *************************************************************************************************** ##                                Check if Testrun is suspect ## **************************************************************************************************** ## Only compare Testcase Version with Testrun's testcase version (== suspect check) if a Testrun exists #if($bFirst == true) ## Add empty cell if no testrun exists <td></td> #else #set($testRunVersion = $mathTool.toInteger($testRunDao.getTestRun($latestTestRunId).getTestCaseVersionNumber()) )  #set($testCaseVersion = $mathTool.toInteger($docDao.getDocument($leaf).getCurrentVersion().getVersionNumber()))   #if ($testCaseVersion > $testRunVersion) #set($bgcolor = "red") <td bgcolor="$bgcolor">suspect:V = $testRunVersion </td> #else #set($bgcolor = "white") <td></td> #end #end
    #if($latestTestRunId != "")
    #set($testPlan = $testRunDao.getTestRun($latestTestRunId).getTestCaseVersionNumber())  #set($cellcontentLastTestRun = "#additemURLtoHTMLblank($bAddURL $jamaurl $latestTestRunId $projectid $testRunDao.getTestRun($latestTestRunId).getDocumentKey())&nbsp;(#addURLtoHTMLblank($bAddURL $testcasestatushelpurl $testRunDao.getTestRun($latestTestRunId).getTestRunStatus()))") #else  #set($cellcontentLastTestRun = "not run") #end #set($cellcontent = "$cellcontentLastTestRun")
    ##******************************************************************** ## ****** Show current TestRun and feed statistics ******************* ##******************************************************************** #set($bgcolortestrunstatus = "white") #if($testRunDao.getTestRun($latestTestRunId).getTestRunStatus() == "BLOCKED") #set($bgcolortestrunstatus = "yellow") #set($nReqWithTestCaseWithBlockedTestRun = $nReqWithTestCaseWithBlockedTestRun + 1) #elseif($testRunDao.getTestRun($latestTestRunId).getTestRunStatus() == "FAILED") #set($bgcolortestrunstatus = "red") #set($nReqWithTestCaseWithFailedTestRun = $nReqWithTestCaseWithFailedTestRun + 1) #elseif($testRunDao.getTestRun($latestTestRunId).getTestRunStatus() == "PASSED") #set($bgcolortestrunstatus = "lime") #set($nReqWithTestCaseWithPassedTestRun = $nReqWithTestCaseWithPassedTestRun +1) #else ## NOT_RUN or INPROGRESS #set($bgcolortestrunstatus = "white") #set($nReqWithTestCaseWithNotRunOrInprogressTestRun = $nReqWithTestCaseWithNotRunOrInprogressTestRun +1)      #end #if($bFirst == true) ## case no Test Runs #set($bgcolortestrunstatus = "ORANGE") #set($cellcontent = "No TestRun yet!") #set($nReqWithTestCaseNoTestRun = $nReqWithTestCaseNoTestRun + 1) #end
    <td bgcolor="$bgcolortestrunstatus">$cellcontent</td> ##******************************************************************** ## *********Show Force pass******************************************* ##******************************************************************** #if ($testRunDao.getTestRun($latestTestRunId).getForcePassed() == true) <td>PassWithError</td> #else <td></td> #end ##******************************************************************** ##**************** Show associated Testcycle ************************** ##******************************************************************** #if($bFirst == false) #set($testCycleContent = "#additemURLtoHTMLblank($bAddURL $jamaurl $testRunDao.getTestRun($latestTestRunId).getTestCycle().getId() $projectid $testRunDao.getTestRun($latestTestRunId).getTestCycle().getDocumentKey())") #set($testCycleContent = "$testCycleContent $testRunDao.getTestRun($latestTestRunId).getTestCycle().getName()") <td bgcolor="white">$testCycleContent</td> #end ##******************************************************************** ##**************** Show associated Testplan ************************** ##******************************************************************** #if($bFirst == false) #set($testPlanContent = "#additemURLtoHTMLblank($bAddURL $jamaurl $testRunDao.getTestRun($latestTestRunId).getTestPlan().getId() $projectid $testRunDao.getTestRun($latestTestRunId).getTestPlan().getDocumentKey())") #set($testPlanContent = "$testPlanContent $testRunDao.getTestRun($latestTestRunId).getTestPlan().getName()") <td bgcolor="white">$testPlanContent</td> #end
    </tr> #end ##/ if testcase #end ## / if active item #end ## /Loop over every downstream #set($nReq = $nReq + 1) ## If no testcase for the given item exists increase the no testcase counter #if ($bTestCaseExisting == false) #set($nReqNoTestCase = $nReqNoTestCase +1) #set($bgcolor = "red") <td bgcolor="$bgcolor"></td> ## red empty suspect cell <td bgcolor="$bgcolor">NO-TEST</td> ## red  TC cell <td bgcolor="$bgcolor"></td> ## red empty Testrun suspect cell <td bgcolor="$bgcolor"></td> ## red empty Testrun cell #else  #set($bTestCaseExisting = false) #end #end ##/Loop over every given item
    #if($bNoDetailedList == false) </tbody> </table>#end
    #if($bStatistics == true) <h2>Statistics</h2> <table border="1" cellpadding="1" cellspacing="0" style="border-collapse:collapse"> <thead> <th>Cumulative Statistic</th> <th>Value</th> </thead> <tbody> #if ($numReqSuspect > 0) #set($bcColorSuspectReq = "red") #else #set($bcColorSuspectReq = "white") #end #if ($numReqBadCoverage > 0) #set($bcColorReqCover = "red") #else #set($bcColorReqCover = "white") #end #if ($nReqNoTestCase > 0) #set($bcColorNoTestscase = "red") #else #set($bcColorNoTestscase = "white") #end #if ($numTestCasesSuspect > 0) #set($bcColorTcSuspect = "red") #else #set($bcColorTcSuspect = "white") #end #if ($nTestCaseNoRun > 0) #set($bcColorTcNoRun = "orange") #else #set($bcColorTcNoRun = "white") #end #if ($numTestRunsSuspect > 0) #set($bcColorTrSuspect = "red") #else #set($bcColorTrSuspect = "white") #end #if ($nTestCaseBlocked > 0) #set($bcColorTrBlocked = "yellow") #else #set($bcColorTrBlocked = "white") #end #if ($nTestCaseFailed > 0) #set($bcColorTrFailed = "red") #else #set($bcColorTrFailed = "white") #end #if ($nTestCasePass > 0) #set($bcColorTrPass = "lime") #else #set($bcColorTrPass = "white") #end <tr><td>Number of Requirements</td><td bgcolor="white">$nReq</td></tr> <tr><td>Number of suspect Requirements</td><td bgcolor="$bcColorSuspectReq">$numReqSuspect</td></tr> <tr><td>Number of Requirements with bad coverage</td><td bgcolor="$bcColorReqCover">$numReqBadCoverage</td></tr>
    <tr><td>Number of Requirements w/o any Test Case</td><td bgcolor="$bcColorNoTestscase">$nReqNoTestCase</td></tr> <tr><td>Number of Tests </td><td bgcolor="white">$numTestCases</td></tr> <tr><td>Number of suspect Tests</td><td bgcolor="$bcColorTcSuspect">$numTestCasesSuspect</td></tr> <tr><td>Number of Tests without Testrun</td><td bgcolor="$bcColorTcNoRun">$nTestCaseNoRun</td></tr> <tr><td>Number of suspect Testruns</td><td bgcolor="$bcColorTrSuspect">$numTestRunsSuspect</td></tr> <tr><td>Number of Tests BLOCKED</td><td bgcolor="$bcColorTrBlocked">$nTestCaseBlocked</td></tr> <tr><td>Number of Tests FAILED</td><td bgcolor="$bcColorTrFailed">$nTestCaseFailed</td></tr> <tr><td>Number of Tests PASS</td><td bgcolor="$bcColorTrPass">$nTestCasePass</td></tr> <tr><td>Number of Tests that are in progress or not executed yet.</td><td bgcolor="white">$nTestCaseInProgress</td></tr> </tbody> </table>#end
    #if($bStatistics == false && $bNoDetailedList == true) <h2>Dear user $actualUser,</h2> <h2>your selected options are possible, but make no sense : an empty page is the result. Please make sure to selected the desired options.</h2> <h2>Best regards from your favorite JAMA admin.</h2>#end
    </body></html>
    As an admin, use the following settings in the admin-reports section:
    Sebastian
    Sick AG
    Attachment(s)
    txt
    TestCoverageGithub.txt   16K 1 version
  • 6.  RE: Get a list of the latest test runs for a set of test cases
    Posted 11-27-2019 09:10
    @Sebastian
    Thanks for posting this, I just had trouble uploading a .vm file as well, put in a ticket with my vendor to see if they can add this extension to m​y white list. Stay tuned!
    Keep sharing!
  • 7.  RE: Get a list of the latest test runs for a set of test cases
    Posted 11-28-2019 03:08
    Hi Sebastian,
    Thank you very much for uploading this! I will try to check it out, but it looks exactly like what I'm looking for.
    Best regards,
    Jonas
    Jonas Granquist
  • 8.  RE: Get a list of the latest test runs for a set of test cases
    Posted 12-02-2019 07:10
    Hi all!
    Also, know what version of Velocity you are using. We just made a newer version available as of 8.42, so if your organization decided to upgrade you will want to look at this New Velocity FAQ to see what the changes are and how to convert this code snippet into the new Velocity. There is a script linked in this document to help facilitate that.
    FYI, just found out for sure that the .vm extension is not on my whitelist for this platform so you do have to just upload it as text.
