Review Comment Export
  • 1.  Review Comment Export
    Posted 06-11-2018 06:34
    Hi all,
    I am working to pull all the review comments for customized filters and need to generate the report.
    In report i need to include following fields
    1) Comment ID
    2) Comment Type
    3) Comment Text
    4) Comment Created Date
    5) Comment Creator
    For Ex: In the customized filter, i have 4 test cases and each test case having 6 different type of comments. So i need to pull all type of comments and generate the report for 4 test cases.
    Please guide me on the same to achieve this.
    Sathish Babu
  • 2.  RE: Review Comment Export
    Posted 06-11-2018 15:28
    Edited by Dana 06-11-2018 15:28
    Hello Sathish,
    You mention each Test Case would have 6 different types of comments. Are you referring to the comments in the review center such as "General Comment", "Question", "Proposed Change" and "Issue"? If so, what are the other 2 types of comments? If you are referring to other types of comments please give me more information on these. Thank you.
    Dana Medhaug
    Technical Support Engineer
  • 3.  RE: Review Comment Export
    Posted 06-12-2018 23:49
    Hi Dana,
    Thanks for the reply.
    I mean 6 types of comments are comments given by reviewer in each type. Like the below one:
    1) First Comment => General comment
    2) Second Comment => Proposed Change
    3) Third Comment => General comment
    4) Fourth Comment => Question
    5) Fifth Comment => Issue
    6) Sixth Comment => Proposed Change
    Sathish Babu
  • 4.  RE: Review Comment Export
    Posted 06-14-2018 10:39
    Hi Sathish,
    Have you tried running the Review Center Comments Report? See images below. The first one shows the result of the report and the second one shows the steps taken to use the report.
    n2ggoBjDTWKmpzmEp9Dn_Screen Shot 2018-06-14 at 10.18.45 AM.pngsDFfHgHrQCGUBVdmw4VQ_Screen Shot 2018-06-14 at 10.24.14 AM.png
    Dana Medhaug
  • 5.  RE: Review Comment Export
    Posted 06-17-2018 23:36
    Thanks Dana,
    Yes i tried this one as well as "Review Center Stats Report" also. But now, there is a small change in the functionality.
    I want to pull out all these details using Rest Api by sending the filter id. Is there any way to achieve this one?
    Sathish Babu
  • 6.  RE: Review Comment Export
    Posted 06-19-2018 17:36
    Hello Sathish,
    I will reach out to some colleagues and get some input on how you can achieve this with the API. Thank you for your patience.
    Dana Medhaug
  • 7.  RE: Review Comment Export
    Posted 06-20-2018 14:49
    Hi Satish,
    Jama does not yet have a way to access the Review Center data with the API. There is a Feature Request for this I would encourage you to comment on!
    Feature Requests - Review Center API
    I also see you've asked a similar question, which Harald sent you a report he built for something similar, which is great!
    Best Practices - Jama Software Community - RE: Generate review comments report for a filter
    Can I ask what you are looking for that is NOT a result from the Review Center Comments Report? Dana pointed out the Comment Type is listed from that Report which is what you specified you needed in your original question.
    Sara Jensen
    Developer Support Engineer
