StackOverflowError
  • 1.  StackOverflowError
    Posted 18 days ago
    Jama 8.31.3 spams its log with these exception backtraces:
    2020-01-31 15:12:00,153 ERROR QuartzScheduler_Worker-13 [org.quartz.core.ErrorLogger] - Job (jama-email.jama-commentWithEmail threw an exception.
    org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: java.lang.StackOverflowError]
     at org.quartz.core.JobRunShell.run(JobRunShell.java:213)
     at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)
    Caused by: java.lang.StackOverflowError
     at java.base/java.util.Collections$UnmodifiableCollection$1.<init>(Collections.java:1042)
     at java.base/java.util.Collections$UnmodifiableCollection.iterator(Collections.java:1041)
    Any idea what could be causing this?
    Christian Bauer
  • 2.  RE: StackOverflowError
    Posted 15 days ago
    @Christian
    Could you make a ticket with our Support team and connect a Support Bundle to it? We would need to take a deeper dive at the logs here. We also have some questions for you about any UI behavior attached to these log errors?
    Christian, when you make that ticket please attach a link to this Community conversation as well as the support bundle. Ill look out for the ticket!
