  • 1.  Retrieve Filter Details
    Posted 08-17-2018 23:51
    Edited by Sathish Babu 08-17-2018 23:52
    Is any one tried to retrieve filters details using filter ID?
    I have filter id, now i want to retrieve the name of filters using id to show in the report. I tried by using FilterDao but its not working, am getting empty result only.
    Example:
    #set($filterDao = $applicationContext.getBean("filterDao"))
    #set($filterDet = $filterDao.getFilter(3404))
    Output:
    FilterDet: $filterDet
    Please correct me if i am doing anything wrong.
    Thanks in advance.
    Sathish Babu
  • 2.  RE: Retrieve Filter Details
    Posted 08-20-2018 09:31
    Hi Sathish -
    I am not sure this query will work, but sometimes when passing in an integer, you need to convert it to an integer at the same time.
    Try:
    #set($filterDet = $filterDao.getFilter($mathTool.toInteger(3404)))
    Hope that helps.
    Shawnna Williams
  • 3.  RE: Retrieve Filter Details
    Posted 08-20-2018 23:14
    Hi Shawna,
    Thanks for the reply.
    I tried to convert the integer value as you said, but its not working and i am not getting result for that dao.
    Do we need to any other supporting dao's for FilterDao?
    Sathish Babu
  • 4.  RE: Retrieve Filter Details
    Posted 08-20-2018 23:22
    Hi Harald,
    Do we have any query to retrive filters details using filter id?. i tried by running the below query to fetch the detail
    #set($filterQuery = $session.createQuery("select fil from Filter as fil where fil.id = :filterId"))
    But its giving empty result only.
    Is there anyway to get filters details, i have filter id in my hand?
    Sathish Babu
  • 5.  RE: Retrieve Filter Details
    Posted 08-21-2018 01:37
    Hi Sathish,
    Should be possible with the Rest-API
    https://<JamaUrl>/rest/latest/filters/<filter-id>/results
    But calling that authenticated from the velocity template is the challenge.
    regards
    Harald
    Harald Hotz-Behofsits
    Frequentis AG
  • 6.  RE: Retrieve Filter Details
    Posted 08-24-2018 00:30
    Hi Harald,
    Sorry, really i dont know how to use Rest API in Velocity template.
    Can you please help me to pull out filter name from Jama using filter id?
    I have used FilterDAO also, but its not outputting the result.
    Sathish Babu
