i am running scratch-blocks at linux terminal
I got the problem which is
python build.py && webpack
scratch-blocks@0.1.0 prepublish: python build.py && webpack
could you give me a help?
npm WARN prepublish-on-install As of npm@5, `prepublish` scripts are deprecated.
npm WARN prepublish-on-install Use `prepare` for build steps and `prepublishOnly` for upload-only.
npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
> scratch-blocks@0.1.0 prepublish /mnt/e/hit and try/scratch/scratch-blocks
Traceback (most recent call last):
File "build.py", line 39, in <module>
raise Exception("Blockly build only compatible with Python 2.x.\n"
Exception: Blockly build only compatible with Python 2.x.
You are using: 3.8.5 (default, Jul 28 2020, 12:59:40)
[GCC 9.3.0]
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! scratch-blocks@0.1.0 prepublish: `python build.py && webpack`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the scratch-blocks@0.1.0 prepublish script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/soumitya/.npm/_logs/2020-11-05T05_06_36_269Z-debug.log
