I changed the file format to CSV and it worked just fine to import users.
The problem now is that when I create a review, there is no choice for "Outside Project Team" or the green button to "Invite user by email." So the reviewers I just added are not available.
They all show up on the Users Admin page, so they are in Jama - I just can't add them as reviewers.
Please find out why this isn't working.
Thanks. John
[John] [Matthias]
[Principal Court Management Consultant]
[National Center for State Courts]
[Denver] [CO]
[3033084350]
Sent: 05-14-2018 14:45
Subject: User import failed - could not load import plugin
My guess is that you need to save the Excel document as a CSV, but I'd recommend that you contact Jama Support for help working through this.
Steve Gotsch
Product Manager
Sent: 05-10-2018 12:39
I corrected the class name, and got another error - the input file is attached - two email addresses with the columns as directed by the Jama User Guide.
Here's the error message:
Custom Import error:
For input string: "There are errors in your users file. No users have been imported. Please fix your file and try again.
27 user(s) are missing required fields for import:
Row 1: Incorrect number of fields to attempt import for row,
Row 2: Incorrect number of fields to attempt import for row,
Row 3: Incorrect number of fields to attempt import for row,
Row 4: Incorrect number of fields to attempt import for row,
Row 5: Incorrect number of fields to attempt import for row,
Row 6: Incorrect number of fields to attempt import for row,
Row 7: Incorrect number of fields to attempt import for row,
Row 8: Incorrect number of fields to attempt import for row,
Row 9: Incorrect number of fields to attempt import for row,
Row 10: Incorrect number of fields to attempt import for row,
Row 11: Incorrect number of fields to attempt import for row,
Row 12: Incorrect number of fields to attempt import for row,
Row 13: Incorrect number of fields to attempt import for row,
Row 14: Incorrect number of fields to attempt import for row,
Row 15: Incorrect number of fields to attempt import for row,
Row 16: Incorrect number of fields to attempt import for row,
Row 17: Incorrect number of fields to attempt import for row,
Row 18: Incorrect number of fields to attempt import for row,
Row 19: Incorrect number of fields to attempt import for row,
Row 20: Incorrect number of fields to attempt import for row,
Row 21: Incorrect number of fields to attempt import for row,
Row 22: Incorrect number of fields to attempt import for row,
Row 23: Incorrect number of fields to attempt import for row,
Row 24: Incorrect number of fields to attempt import for row,
Row 25: Incorrect number of fields to attempt import for row,
Row 26: Incorrect number of fields to attempt import for row,
Row 27: Incorrect number of fields to attempt import for row,
[John] [Matthias]
[Denver] [CO]
[3033084350]
Sent: 05-09-2018 00:58
I followed the directions in the tutorial for importing users after adding the plugin, using the Custom Import window.
The import failed (small test spreadsheet of two users). The message is "Unable to load import plugin." I copied this from the tutorial: codecom.jamasoftware.contour.plugin.jama.UserImportPlugin when I added the plugin.
What's wrong?
Thanks. John
[John] [Matthias]
[Denver] [CO]
[3033084350]
