Product Idea
Possibility to see / filter tags in a list view
  • 1.  Possibility to see / filter tags in a list view
    Posted 11-24-2016 23:11
    It would be good to have a possibility to see and filter tags on the list view. Currently tags cannot be added as a column and also it is not possible to filter based on them (quick filter) for list view.
    Thank you for considering this idea
    Vlada
  • 2.  RE: Possibility to see / filter tags in a list view
    Posted 11-28-2016 06:30
    This is a good idea. Lack of visibility is one reason I avoid tags.
    The second reason I avoid tags is typically I observe that only the person that created the tag will use the tag. Lack of visibility could be a cause for this behavior.
    Jonathan LastName
    IT Manager & Systems Analyst
    Fidelity Investments
    Merrimack NH
  • 3.  RE: Possibility to see / filter tags in a list view
    Posted 11-29-2016 06:15
    Our user community would like this feature as well since the Tags option is used regularly.
    John
    John Sarafin
    UPS
  • 4.  RE: Possibility to see / filter tags in a list view
    Posted 02-28-2017 13:52
    I agree.
    We also use tags.
    I would like to see tags in filtered views.
    Ken G
    ASR
  • 5.  RE: Possibility to see / filter tags in a list view
    Posted 05-25-2017 07:50
    Agreed.  We use tags often.  Not having them in list view is driving users to export and work in rogue spreadsheets (not good).
    Steve Miller
    Caterpillar Trimble Control Technologies, LLC
  • 6.  RE: Possibility to see / filter tags in a list view
    Posted 12-26-2019 13:43
    I agree. We use tags a lot and sometimes tag items temporarily such as when we need to group together a set of test cases for a specific project and need to remove those tags when we are done. Since you can only remove tags from one item at a item and cannot see them in list views, it is very cumbersome to edit and remove tags for multiple items. This has forced us to create a lot of custom fields which still don't give us the flexibility that tags do.
    vm
    TaxResources, Inc.
