Add a step to the review wizard that enables moderator to preview content
It would be helpful to have a step added to the Review creation wizard that enables the user to preview how the review will appear when it is created. While filters are helpful to create reviews, sometimes tags aren't properly added by other users. There are other cases in which errors can occur when adding requirements to a review. It would help to have a test run in the wizard process, rather than requiring users to create separate filters or other views first, to double-check. Thanks!
Sandy, that's an interesting suggestion. Thanks for sharing it. So you'd like the reviewer to get an overview of all the content in the review before publishing it? And then if they notice missing or incorrect info, they could go a step back and correct it?0
Yes. I'm not Sandy, but I'm answering from my perspective. This would be a feature that we would be interested in as well. Today, we have some associates that send out a "test" review to themselves or a peer just so they can review to see what it looks like before sending it out to our business partners for review.0
Not sure yet whether we would find this useful but this is an interesting idea, could be good! Although you are able to add more content (e.g. forgotten) to the review at the moment, it's quite troublesome.0
Yes...that is what I meant. I have also used the test review to see what it looks like. This is a workaround, but a bit of a pain point.0
I just had that issue again myself this morning. If you use a filter to create the review based on tags, it is OK. But we often have to use the pick-and-choose method, so adding missing requirements after a review has been posted is troublesome.0
Angie and Sandy—thanks for elaborating on the importance and advising of what you do now. Good to know.0
