Configurable Chart Color Selection Request
Currently JAMA fixes the Bar Chart and Pie Chart for non enumerated type to the color green.
It would be good to have the Chart Color configurable/selectable.
For example, I have a Dashboard Widget that alerts the Team for the set of Requirements that do not have a downstream Test Case. Currently this Widget displays the Bar Chart result in a Green bar.
Since this widget is part of my QA Widget checks which alerts the team that there's a traceability gap and hence work to due, this Bar Chart color should be Red, not Green.
Regards
Regards
Thanks for posting the idea, Kurt!
If anyone is curious regarding the context of this, it can be found in this thread about configuring Dashboard Widgets.0
