Export impact analysis result should be exportable to Excel
Yuheng He
Member Posts: 11
It would be nice that the result of the "Impact Analysis" can be export as Excel file, which is the same as what the "Coverage Explorer" for "Traceability" can do now.
Hi Yuheng! Welcome to the community and thanks for sharing this idea. We're working on improving coverage views, so I'll make sure our team sees this idea since it's extremely pertinent! Can I inquire what reason you need to export the Impact Analysis? Is there a stakeholder or another team to whom you need to deliver this info?0
Hi Kristina, we use JAMA to specify requirements from the beginning of the Market analyse till the the product validation. So the are a lot of requirements on each development level and are related to each other. E.g. there are MRS_REQ, PRS_REQ, SAS_REQ from up to down in the V-model. If there is any requirement in PRS_REQ should be changed, we have to figure out which requirements are affected and on which level (how many requirements on MRS, PRS or SAS are affected). And depending on the number of the affected requirements and the related efforts to change them, we can decide, whether the change to the requirement in PRS_REQ should be made or not. With an impact analyse Excel report it would be very helpful for us to do a reporting to each department.0
We have also the same need. Sometimes requirements from stakeholders may impact to multiple items in multiple relationship levels, so the excel export would help person to work with the requirement more efficiently.0
