Ability to send hyperlink to filter or text search
I would really like the ability to hyperlink to filters and to URL encode text search.
For example, if i have a filter named "items for team X", i would like an easy ability to send an email with a hyperlink to "items for team X". It is often difficult to get users to go find the filter for themselves, especially managers who aren't in Jama every day.
A simple url extension such as ?projectId=11&filterId=1234 seems perfect.
In addition, being able to URL encode a filter would be even better
?textSearch=id:123456 OR 123457, which when URL encoded would look like ?textSearch=id:123456%20OR%20123457
or more advanced searches such as
?textSearch=+custom_field_a:some value +custom_field_b:some other value
I have a specific use case where if I can simply URL encode the list of API IDs and get jama to load that, we would be in really good shape.
Preston Mitchell Jama Staff, Vertical Solutions Moderator, Data Exchange, Jama Connect Interchange™ (JCI), Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 7OptionsThis is a workaround (doesn't solve the true issue) but you can create a Project widget that contains the filter results
and then send a hyperlink to the actual Jama Project which opens the dasbhoard. Go to any item and choose Actions > Email Link. The first portion of the URL is a general project URL which opens the Project Dashboard.
Preston
Jama Software0 -
Tom, I wanted to let you know that direct linking to a filter URL is going to be made available in our hosted offering soon. This means our fall on-premises release should have this function in it. We're working on creating contextual URLs to projects, items, containers and filters.0
I've marked this idea as Implemented, as the most recent hosted release (2015/05/20) included the ability to directly link to a filter, e.g.
https://www.yourjama/perspective.req#/filters/56773?projectId=24121<br>
One of our Product Managers, Derwyn, wrote an article outlining this feature if you'd like to see all that Contextual URLs bring to the table.0 -
Hi Kristina, we are using 2015.3 version of Jama (Dec build) but cannot see options for sharing URL to filters described here. This is an excellent feature that we would like to utilise as one way of reporting changes and status to managers and stakeholders. We can see the direct link to item options for individual items, as in the previous versions just not for filters. Are we on the correct version to see this enhancement? Thanks.0
Ivona, thanks for bringing this up. You aren't missing anything. As it turns out, this feature (URL Routing) did not make it into our latest on-premises release. The on-premises release focused on performance enhancements and bug fixes, so very few of the features seen in hosted made it in. So it's still yet to come.0
Kristina, thanks for explainining. Are there known timelines for when this feature would become available? Thanks.0
We haven't yet finalized the list of features for the next release, but if all goes to plan, 2016.1 (due in the next quarter) will include this feature.0
One other quick note: regarding the original feature request to be able to manually build a filter via URL encoding, it looks like this is possible with the new contextual URLs. If you create a new filter and click the "View in List" button, the filter results will be shown under a filter preview URL with all the parameters.
Fair warning: the URL is crazy long and would undoubtedly require a lot of tinkering to make sense of it, but thought I'd share just in case.
Example URL:
[...]/jama/perspective.req#/filters/preview/{%22id%22%3Anull%2C%22filterAuthor%22%3A72%2C%22name%22%3A%22My%20Filter%22%2C%22scopeId%22%3A3%2C%22refId%22%3A87%2C%22isPublic%22%3Afalse%2C%22testCenterItemCategory%22%3Anull%2C%22currFilterId%22%3A8%2C%22smartFilterQuery%22%3A{%22filterRule%22%3A{%22id%22%3A0%2C%22operator%22%3A%22GROUP_AND%22%2C%22filterRules%22%3A[{%22id%22%3A1%2C%22parentId%22%3A0%2C%22operator%22%3A%22GROUP_OR%22%2C%22filterRules%22%3A[{%22parentId%22%3A1%2C%22id%22%3A2%2C%22docType%22%3A37%2C%22field%22%3Anull%2C%22operator%22%3A%22GROUP_OR%22%2C%22values%22%3Anull%2C%22filterRules%22%3A[{%22parentId%22%3A2%2C%22id%22%3A6%2C%22docType%22%3Anull%2C%22field%22%3A{%22id%22%3A256%2C%22name%22%3A%22name%22%2C%22display%22%3A%22Name%22%2C%22fieldDataType%22%3A2%2C%22type%22%3A1%2C%22actualDataType%22%3A%22string%22%2C%22canRemoveField%22%3Afalse%2C%22dataType%22%3A%22string%22%2C%22dataTypeId%22%3A2%2C%22documentFieldId%22%3A2%2C%22enumType%22%3A%22%22%2C%22field%22%3A%22name%22%2C%22hidden%22%3Afalse%2C%22isSocialTraceabilityField%22%3Afalse%2C%22isSynchronizeField%22%3Atrue%2C%22isWorkflowField%22%3Afalse%2C%22label%22%3A%22Name%22%2C%22mappedForImport%22%3Afalse%2C%22readOnly%22%3Afalse%2C%22required%22%3Atrue%2C%22sortOrder%22%3A7%2C%22triggerSuspect%22%3Afalse%2C%22userConfigurable%22%3Atrue}%2C%22operator%22%3A%22CONTAINS_WORD%22%2C%22values%22%3A[%22leak%22]%2C%22filterRules%22%3A[]%2C%22subQuery%22%3Anull}]}]}%2C{%22parentId%22%3A0%2C%22id%22%3A4%2C%22docType%22%3Anull%2C%22field%22%3A{%22name%22%3A%22modifiedDate%22%2C%22field%22%3A%22modifiedDate%22%2C%22dataType%22%3A%22date%22}%2C%22operator%22%3A%22IS_WITHIN_LAST%22%2C%22values%22%3Anull%2C%22filterRules%22%3A[]}]}%2C%22name%22%3A%22%22%2C%22projectList%22%3A[]%2C%22orderByRule%22%3A{%22id%22%3A7%2C%22field%22%3A{%22id%22%3A251%2C%22name%22%3A%22sequence%22%2C%22display%22%3A%22Heading%22%2C%22fieldDataType%22%3A2%2C%22type%22%3A1}%2C%22direction%22%3A1%2C%22nextRule%22%3Anull%2C%22value%22%3A251}}%2C%22showCategories%22%3Afalse%2C%22typeId%22%3A37}?projectId=87
Same URL without % character encoding for slightly easier reading:
[...]/jama/perspective.req#/filters/preview/{"id":null,"filterAuthor":72,"name":"My Filter","scopeId":3,"refId":87,"isPublic":false,"testCenterItemCategory":null,"currFilterId":8,"smartFilterQuery":{"filterRule":{"id":0,"operator":"GROUP_AND","filterRules":[{"id":1,"parentId":0,"operator":"GROUP_OR","filterRules":[{"parentId":1,"id":2,"docType":37,"field":null,"operator":"GROUP_OR","values":null,"filterRules":[{"parentId":2,"id":6,"docType":null,"field":{"id":256,"name":"name","display":"Name","fieldDataType":2,"type":1,"actualDataType":"string","canRemoveField":false,"dataType":"string","dataTypeId":2,"documentFieldId":2,"enumType":"","field":"name","hidden":false,"isSocialTraceabilityField":false,"isSynchronizeField":true,"isWorkflowField":false,"label":"Name","mappedForImport":false,"readOnly":false,"required":true,"sortOrder":7,"triggerSuspect":false,"userConfigurable":true},"operator":"CONTAINS_WORD","values":["Altitude"],"filterRules":[],"subQuery":null}]}]},{"parentId":0,"id":4,"docType":null,"field":{"name":"modifiedDate","field":"modifiedDate","dataType":"date"},"operator":"IS_WITHIN_LAST","values":null,"filterRules":[]}]},"name":"","projectList":[],"orderByRule":{"id":7,"field":{"id":251,"name":"sequence","display":"Heading","fieldDataType":2,"type":1},"direction":1,"nextRule":null,"value":251}},"showCategories":false,"typeId":37}?projectId=87
Trent Hirsch
Plexus Corp (On-Premise)
Sent: 03-17-2015 16:46
Subject: Ability to send hyperlink to filter or text search
I have a specific use case where if I can simply URL encode the list of API IDs and get jama to load that, we would be in really good shape.0
