Enable custom field selection and column order in all saved filters
Enable custom field selection and column order in all saved filters.
Motivation:
Filters are created to show a subset of all information available in the database. Sometimes the information of interest is similar between two filters and it makes sense to have the same columns showing in the same order. Sometimes not.
I have made use of this requested functionality in other relational database tooling and it enabled the example use case below.
Example Use Case:
Project manager creates a filter that shows only the requirement ID, name and its verification status. This filter is referred to by the project team as the Requirement Test Result filter always shows just these three columns of information.
This example is a real use case in our company. It supports a larger theme (our greatest motivation to embrace Jama), which is our desire to provide hyperlinks to filtered information in the Jama database instead of manipulating content in Excel, uploading and hyperlinking to SharePoint.
Thermo Fisher Scientific
Tom, thank you for sharing this idea—I appreciate the clear context and use case. I think it makes perfect sense!0
Any update on this? It's been 5 years and this seems a pretty basic but necessary part of filters.0
Hi Scott,
Thank you for calling attention to this Product Idea. Please note, I've created a card for this in our Ideation space as I noticed this topic hadn't been addressed in there.
Ideation Product Idea - Enable Custom Field Selection and Column Order In All Saved Filters
Please visit that link and comment/like it to reflect your support of it. More on our Ideation process below:
The Ideation module was launched in May 2020 and is specifically designed to facilitate conversation's around the continual evolution of the Jama Connect product. Our feedback loop is outlined here: Jama Software Community Product Idea Process.
Your submissions can be filtered and found in multiple ways; category, votes, status, most recently submitted, etc. You can also use the dynamic search bar capability to search the cards for any similar ideas, (hint: getting into the habit of crafting a relevant title will help this function work for everyone) then vote/comment on a similar idea or post a new one! Look around, vote, comment, and post your ideas.
Let us know if you have any questions.Decoteau Wilkerson
Content Marketing Specialist
Oregon0
