Search inside diagrams
Morten Proschowsky
Morten Proschowsky Member Posts: 8
edited July 2016 in
Would it be possible to extend the Jama search function, to also be able to search in text inside Jama diagrams?
    [Deleted User] Posts: 911
    edited June 2016
    Thanks for sharing this idea, Morten. How often do you see text in your diagram that is not reflected elsewhere in that item? Do you label heavily in the diagram? Or include large swathes of text that aren't elsewhere in the item?
  • Morten Proschowsky
    edited June 2016
    For our use of Jama it is very common to have items that only contain a diagram. We try to avoid having duplicated information in our requirements, so mostly the item contains very little text except for the diagrams.
    We mainly use diagrams to describe user interaction, so the diagrams are mostly flowcharts with annotations.
    edited June 2016
    Ah, now I understand why search in diagrams is so important. Thanks for adding that.
    [Deleted User] Posts: 160
    edited March 2016
    I think this is theoretically possible.  The diagram data is stored as XML that could be indexed.   As more customers express need for this we will certainly consider it.
    [Deleted User] Posts: 73
    edited March 2018
    has the "search inside diagrams" feature been discussed again?
    We are looking for this feature as well, because we are thinking about moving our Design Specificaitons (which are UML) over to Jama. Not being able to search for e.g. class names within all the specs might be a blocker at the moment.
    Looking forward to answers,
    Anna Henke
