Product Idea
In list view provide possibility to select "Wrap text" (equivalent to Excel).
  • 1.  In list view provide possibility to select "Wrap text" (equivalent to Excel).
    Posted 12-22-2015 09:08
    In list view provide possibility to select "Wrap text" (equivalent to Excel)also in Filter view.
  • 2.  Re: In list view provide possibility to select "Wrap text" (equivalent to Excel).
    Posted 12-22-2015 15:39
    Thanks for the idea, Cosmin! Can you elaborate on the need for this feature? The Reading view will display the Description as wrapped. Is this because you need to see a lot of content in other fields in the same view?
  • 3.  Re: In list view provide possibility to select "Wrap text" (equivalent to Excel).
    Posted 05-13-2016 02:20
    Wrap Text in any field would be helpful as. Ex . A text wrap in Test steps allows the author to see his step clearly instead of resizing the Action and Expected Results field every time user enters a lot of text in these fields. Plus it will be helpful if these fields are Rich Text as well.
  • 4.  Re: In list view provide possibility to select "Wrap text" (equivalent to Excel).
    Posted 05-13-2016 14:08
    That's true. Thanks for pointing that out, Dheerendra.
  • 5.  RE: Re: In list view provide possibility to select "Wrap text" (equivalent to Excel).
    Posted 09-25-2018 12:17
    Hi Jama -
    What's the status of this feature request? We are rolling out Jama Connect and are already receiving feedback that the lack of "wrap text" capability is a problem. We prefer list view to reading view because 1) we often like to see multiple fields along with requirement text and 2) we like to be able to view many requirements simultaneously.
    I would love to know when this is added to your roadmap.
    Theresa
    Fujifilm SonoSite
    WA United States
