Feature Request: Ability to configure default item Reuse Rules
Victor Cheung
Member, Data Exchange Posts: 90
Currently, when reusing items, the user has to remember to click into the "Advanced" view and then select the correct rule to apply. If reuse rules could be attached to an item as a default rule that would always trigger upon reuse then it would make this process a lot easier and remove human errors. The ability to do this organization-wide or on a per project basis would be a great feature enhancement.
victor
Thanks for the feedback, Victor.0
Agree. We would like to turn off "sync" by default. This has caused a lot of problems with users that aren't trained on how to use sync functionality.Tom Green
Thermo Fisher Scientific0 -
bump! still a very much desired new feature for us. causing lots of problems as casual Jama users always forget to go into Advanced to select the proper reuse rule.victor0
hi, we are having the same issue. Can anybody explailn the reason/ benefit of having it synchronisation set as default? We are reusing objects not copying so I can't see a benefit of having a sychronisation set as default value. I agree it's useful to have the option to create synchronisation but as a option not as default value. It is causing us lots of issue.0
