Product Idea
Feature Request: Ability to configure default item Reuse Rules
  • 1.  Feature Request: Ability to configure default item Reuse Rules
    Posted 07-25-2016 11:44
    Currently, when reusing items, the user has to remember to click into the "Advanced" view and then select the correct rule to apply. If reuse rules could be attached to an item as a default rule that would always trigger upon reuse then it would make this process a lot easier and remove human errors. The ability to do this organization-wide or on a per project basis would be a great feature enhancement.
  • 2.  Re: Feature Request: Ability to configure default item Reuse Rules
    Posted 07-26-2016 14:24
    Thanks for the feedback, Victor.
  • 3.  RE: Feature Request: Ability to configure default item Reuse Rules
    Posted 07-18-2017 15:57
    Agree.  We would like to turn off "sync" by default.  This has caused a lot of problems with users that aren't trained on how to use sync functionality.
    Tom Green
    Thermo Fisher Scientific
  • 4.  RE: Feature Request: Ability to configure default item Reuse Rules
    Posted 02-04-2019 04:54
    bump!  still a very much desired new feature for us.  causing lots of problems as casual Jama users always forget to go into Advanced to select the proper reuse rule.
    victor
  • 5.  RE: Feature Request: Ability to configure default item Reuse Rules
    Posted 10-25-2019 03:48
    ​hi, we are having the same issue. Can anybody explailn the reason/ benefit of having it synchronisation set as default? We are reusing objects not copying so I can't see a benefit of having a sychronisation set as default value. I agree it's useful to have the option to create synchronisation but as a option not as default value. It is causing us lots of issue.
    Maria Kenderkova
    Aker Solutions
