Feature Request: Ability to configure default item Reuse Rules
Victor Cheung
Victor Cheung Member, Data Exchange Posts: 90
edited August 2016 in
Currently, when reusing items, the user has to remember to click into the "Advanced" view and then select the correct rule to apply. If reuse rules could be attached to an item as a default rule that would always trigger upon reuse then it would make this process a lot easier and remove human errors. The ability to do this organization-wide or on a per project basis would be a great feature enhancement.
victor
    [Deleted User] Posts: 911
    edited July 2016
    Thanks for the feedback, Victor.
  • Tom Green
    Tom Green Member Posts: 56
    Agree.  We would like to turn off "sync" by default.  This has caused a lot of problems with users that aren't trained on how to use sync functionality.
    Tom Green
    Thermo Fisher Scientific
  • Victor Cheung
    edited February 2019
    bump!  still a very much desired new feature for us.  causing lots of problems as casual Jama users always forget to go into Advanced to select the proper reuse rule.
    victor
  • Maria Kenderkova
    Maria Kenderkova Member, Data Exchange Posts: 1
    edited October 2019
    hi, we are having the same issue. Can anybody explailn the reason/ benefit of having it synchronisation set as default? We are reusing objects not copying so I can't see a benefit of having a sychronisation set as default value. I agree it's useful to have the option to create synchronisation but as a option not as default value. It is causing us lots of issue.
