Reuse Multiple Times
[Deleted User] Posts: 46
edited September 2016 in
Hello! We have a request from a use to have the ability to reuse multiple times by being able to select a number of times to reuse (vs reusing over and over and over). The user indicated as follows:
"When reusing Test Cases it would be helpful if we were able to say how many times we would like to reuse the Test Case. For my current project there are 95 Test Cases that will be very similar and it would have saved quite a bit of time if I could have said Reuse 94 times instead of individually. I did build 15 of them and just reuse the folder but then they had to be pulled out of their folders and moved into the main folder."
    [Deleted User] Posts: 911
    edited August 2016
    That makes a lot of sense and is more analogous to a copy-and-paste ability. Thanks for the idea!
