Product Idea
Should be able to nest Filters
Harald10-24-2016 05:09
  • 1.  Should be able to nest Filters
    Posted 06-27-2016 01:50
    Hi Folks,
    I'm a bit surprised (and not pleasantly so) by the very limited 'filter nesting' functionality in Jama.
    I've previously been a Cradle user and found that the ability to nest queries was a fantastic feature. (It allowed me to write nested queries that were complex enough that I didn't mind not being able to write them in SQL.)
    As far as I can see, in Jama a Filter can have only one "level of nesting." That is, when creating a filter and using a search term such as "Has upstream items," I can created an Embedded Filter. BUT that's it - I can't go on to embed a further filter inside the first embedded filter.
    Worse still, the set of search terms for the embedded filter doesn't include "Has upstream items" or other similar terms. This put pretty severe limitations on my ability write a complex query (or 'filter' in Jama-speak).
    What I'd like to be able to do would be:
    1) When I'm using a search term that leads to "that match this filter" being displayed, I'd like to be able to choose a "regular" (as opposed to embedded) filter that I'd created earlier. That is, I'd like to be able to nest a "top level" filter inside another "top level" filter.
    2) And I'd like to be able to iterate this process several times. That is, create and save 'Filter A' then nest that inside Filter B then nest Filter B inside Filter C and so on.
    I'm hoping that this idea makes sense - does it??
    Cheers,
    Ian
  • 2.  Re: Should be able to nest Filters
    Posted 06-27-2016 12:33
    Hi Ian,
    Yes, this need/want makes complete sense. I was just stymied by this nesting limitation when I was trying to export a bug list with many relationship conditions. I'm surprised this hasn't come up more before, though—I just took a look through other filtering Ideas and you're the first to suggest this. (Although others have suggested in the past more super-user filtering similar to SQL query.) I really don't know what the next phase is for the advanced filters in Jama, but I hope this is something we can work on.
  • 3.  Re: Should be able to nest Filters
    Posted 06-27-2016 13:32
    This was already a topic in the old Forum.
  • 4.  Re: Should be able to nest Filters
    Posted 06-27-2016 15:38
    Yes, you're right. (I just looked in here for one to merge it with.)
  • 5.  Re: Should be able to nest Filters
    Posted 06-30-2016 23:43
    Ian, I can see how you were surprised and frustrated with lack of nesting, I feel the need to create multi-level filters several times in the past year, a very tedious workaround is to do a two level search and then tag the results with a temporary tag, then search those tagged items and then search again. Very tedious. Hopefully Jama might consider improvements in this area. Good luck. Swoo
  • 6.  Re: Should be able to nest Filters
    Posted 07-06-2016 15:52
    Ouch. That's a good workaround, but you are right—that is very tedious. I'd love to have nested filters.
  • 7.  Re: Should be able to nest Filters
    Posted 10-21-2016 11:30
    I would second Ian's sentiment. Even the ability to go "upstream" once and then "upstream" once again from that would be fantastic.
    In our case we are using filters to determine which test cases should be included in each test plan based on upstream requirements and further upstream product variants. It would be nice to be able to filter upstream twice to get to results based on information from that higher level as well.
  • 8.  Re: Should be able to nest Filters
    Posted 10-24-2016 05:09
    We have the same use case.
  • 9.  Re: Should be able to nest Filters
    Posted 10-26-2016 16:04
    I often need to use multiple single embedded filters to capture items I could get with just one if I could embed more than one level.  Even one more layer would be a huge improvement.
  • 10.  RE: Re: Should be able to nest Filters
    Posted 05-17-2017 22:00
    Well, it's been I while since I last howled about nested filters so I guess it's time ...
    This really is at the top of my enhancement wish list and I'd love to know if there has been any progress on getting some action on this feature.
    The particular use case that was frustrating me today was trying to build a Test Plan. I wanted to be able to use a filter to "show me the Test Cases that have upstream relationships to the System Requirements that are located in folder x"
    I'm trying to bring some more people - testers - into the 'Jama fold' and this is causing me some issues with this.
    A minor (?) improvement that might be possible without too much effort would be to address the use case I mentioned above. That is, for the existing embedded filter, expand the list of matching criteria to include Location.
    Ian Webb
    Enphase Energy, Inc.
  • 11.  RE: Re: Should be able to nest Filters
    Posted 05-19-2017 15:18
    Hi Ian,
    Currently Jama does not have plans on the roadmap to make changes to the filters. Sorry for the frustrations you are dealing with.
    Dana Medhaug
    Business Support Engineer
    Jama
  • 12.  RE: Re: Should be able to nest Filters
    Posted 05-30-2017 22:54
    I also have a similar use case - I have stories -> functional requirements -> test cases.  The delivery team works based on stories and my testers want a filter to show stories that have functional requirements, which do not yet have test cases.
    The best I can do is filter to a list of functional requirements that have upstream stories but no downstream test cases.  But Id prefer to show the stories.
    Callum Davey
  • 13.  RE: Re: Should be able to nest Filters
    Posted 08-09-2017 15:02
    Another +1 on this request
    Alaina Curran Knapp
  • 14.  RE: Re: Should be able to nest Filters
    Posted 08-10-2017 18:41
    Hi Again,
    Obviously, I'm not alone in being frustrated by the deficiencies of embedded filters. Sadly, the feedback I've received is that there are no plans to improve them.
    So, as a partial solution, I've got a suggestion for what I THINK would be a very limited enhancement: to include "Location" in the available match criteria.
    My use-case for this is that I want to be able to use a filter to show me a filtered selection of Test Cases when I'm building a Test Plan: "Show me only those Test Cases that have have upstream items that match this embedded filter: Product Requirements that are under this Location."
    In the absence of comprehensive improvement of embedded filters, this incremental improvement would be very welcome.
    Ian Webb
  • 15.  RE: Re: Should be able to nest Filters
    Posted 05-30-2018 02:48
    +100 on this request... really, really, need the nested filters functionality.
    Jama, come on... get this done please...
    Devang Sanghrajka
  • 16.  RE: Re: Should be able to nest Filters
    Posted 05-31-2018 08:34
    ​We are already finding this limiting.  I think it will be become a much larger issue as our users become more advanced.
    I would really like to see this improvement.
    Justin Sterkel
  • 17.  RE: Should be able to nest Filters
    Posted 01-21-2019 09:14
    Nested filters would be much more useful than my other suggestion of just Adding Location to the embed filters.  Some of the earlier work arounds like using temporary tags don't play nicely with workflows where tags are locked in certain states.  Plus it is messy and difficult to repeat.
    Matt
  • 18.  RE: Should be able to nest Filters
    Posted 10-25-2019 13:35
    Same concern:
    As a filter creator, I would like to define a Filter as combinations of other Filters, so that
    - I don't need to retype each filter criteria
    - I get build-in consistency.
    Christian Binard
    ON semiconductor
    Belgium
