Dashboard replication
We have asked for this request in the past. A way to create a dashboard as part of a template project. When that template project is duplicated, duplicate the dashboard/widgets/etc as well.0
Thanks. One would think there are a few options for JAMA development in order of desirability:
1. Add replicate dashboard option to duplicate project.
2. Allow users to save the dashboard config locally and upload it to the project.
3. Give customers x number of times per year that JAMA can configure this on the backend, as they must be pointing to a config file on the server. This only works when the customer wants one default dashboard for all projects.
I've found the product is very powerful in reducing admin overload with admin settings, reuse and duplicate project capabilitities. The dashboard gap is the only obstacle to not losing an hour or two per project to productivity.0 -
Thanks for bringing this up, Tony. I agree with you and Angie that duplicating a dashboard as part of Duplicate Project function or creating some sort of template would save admins a lot of time. Thanks for sharing variations on the idea.0
Thanks! So what happens from here?0
Here's how Jama uses the Ideas that customers share. Essentially, when our Product team focuses on an area of Jama to update they take a look at the ideas that have come in for that functional area or feature and consider them. We also have a process where the most popular Ideas get added to other customer requests and prioritized for potential update or inclusion. So in this case the idea wouldn't be added to the priority list because only two customers have "voted" for it, but that may change a month from now as others see it. (I go through this list monthly.)0
So like Hillary, Bernie, Donald and Ben looks like I have to hit the campaign trail0
Yes. I hope you have millions of dollars to support this effort!0
I vote for this functionality0
Folks-
I'd like to propose a slight tweak on this as another alternative, and to raise a related question.
Use Case: There a number of small projects running within an organization and management would like a separate summary dashboard across a number of projects.
In concept, I'm thinking it might be convenient to reference existing dashboard widgets in another dashboard ... as you might across web pages. That is, one (embedded) source widget, and a display of it in multiple places.
I recognize / think this is a little different from the use case here, but it brings up something interesting I've thought about ... a little. The widgets we mostly used are based on filters which are always being tweaked it seems. A few are scoped to the "current project", but the majority, in practice, seem to be tuned to each project.
Bottom line, in my dashboard creation/management experience, much of the work in cloning a dashboard is in replicating the required filters for each widget. (To me to duplicate some dashboards may imply replicating some filters ... which may not be straightforward.)
Any thoughts?
Bob0 -
We generally use standard conventions across projects so all/most of our filters used for dashboards are scoped to the "current project". Regardless, the idea of having a referencable set of dashboard widgets would help.0
Please also consider duplicating the default page layout settings.Tom Green
Thermo Fisher Scientific0 -
This would be great.
We initially thought Jama had this feature when we tested it out. It seems we were so newbie we didn't realize duplicating projects doesn't duplicate the dashboard.
schdc
Sent: 11-04-2016 23:36
Subject: Re: Dashboard replication
0 -
Any updates? Has this been accepted into a backlog?
My users are asking for this too. We have 2 cases.
First, multiple projects want the same dashboard. It would be be helpful to have a template that can be re-used.
Second, with each release we create new widgets. The widgets are the same layout as prior widgets, but using a new filter specific to the release. Users want to copy the existing widgets.
Jonathan LastName
Fidelity Investments - EZPaaS
Sent: 11-15-2016 14:56
Subject: Re: Dashboard replicationThis would be great.
schdc
0 -
hi Jonathan,
There is no update to share on this request. Our winter backlog revolves around testing, REST API and item flow: Product Bulletin: Look Ahead - Winter 2016
KK
Sent: 01-06-2017 14:00
Subject: Re: Dashboard replicationAny updates? Has this been accepted into a backlog?
Jonathan LastName
schdc
0 -
I would really like to see this feature implemented as well. I really like Bob's idea "separate summary dashboard across a number of projects". Having this on the home page would be very beneficial for monitoring a program of several projects. Going one further I would really like to have the ability to have the dashboard available to display continuously on a project status monitor in our project meeting areas.
Randy - Delta Controls
Sent: 04-22-2016 18:05
Folks-
Any thoughts?
Bob
Randy - Delta Controls0 -
+1 from us. The lack of dashboard copy is an annoying pain in the chuckies for our Jama admins.
We use multiple widgets, including custom widgets which contain a bunch of HTML. These have to be manually copied and the dashboard configured every time we create a project.
I'd like to see a "copy dashboard verbatim" option in the duplicate project options.
Grant More
Head of Systems Engineering
Analog Devices
Sent: 01-06-2017 18:55
Subject: Re: Dashboard replicationhi Jonathan,
KK
Jonathan LastName
schdc
Grant More
More Consulting Ltd.0 -
Plus, I like Bob's suggestion of reference widgets. Nice idea Bob, we'd certainly use that a lot.
Grant More
Analog Devices
Sent: 01-09-2017 05:26
Subject: Re: Dashboard replication+1 from us. The lack of dashboard copy is an annoying pain in the chuckies for our Jama admins.
Grant More
Analog Devices
KK
Jonathan LastName
schdc
Grant More
We also would like to see this feature available. Has there been any update on this since 2017?Elizabeth Rosenberg
Alight Solutions0 -
We would also benefit from being able to replicate the dashboards when duplicating projects.Robena Sukhu
Sun Life Financial
ON
416-496-54560 -
Bumping this up again! Where's the dashboard copy when duplicating a project!?0
+10
also + 10
+1 also from meAlessandro
SICK AG0 -
Hello everyone, we are actively doing research on Jama Connect Dashboards. I would like to invite you to provide your insights on this product survey. These will be very valuable in helping us determine our next steps forward. As always, please reach out to me with any questions.
