Rich text for Result field in test run
[Deleted User] Posts: 7
edited December 2018 in
The result field/column is currently a plain text and puts limitation on capturing the result for individual step.
As result capturing and presenting it right way is most important aspect of Test Execution, we would want this field to be of rich text type like other fields in Test Case. This field does not even allows line breaks or paragraph formatting. Additionally, results cannot be a plain and needs capturing the screen shot/ attachments. The current work around is cumbersome for both Tester and reviewers as tester/reviewer has to correlate the result in actual result field.
  • Simon Meng
    Simon Meng Member Posts: 3
    edited June 2019
    Any feedback from the JAMA? This will be very useful.
    Is there another alternative workaround on this?
