we are also very interested in extending the Testcycle funtionality. I like how Jama offers the possibility to generate different test cycles where users can select different testgroups and status, I think it lacks a bit of configuration-possibility:
one should be able to select (e.g. multiple select) the test runs that should be repeated.
Right now it is only possible to "filter" based on the status, but what if one pass test needs to be repeated (e.g. after a SW change) while another does not? Our current workaround is to set the status of the test to "not run", then repeat all not run test in the new cycle and then set the status to pass again (because we still want to have the result of the older run for certification purpose).
This is inconvenient and could be fixed easily (I guess).
Thank you and best regards,
Sebastian
Requirements Engineer
Sick AG
Sent: 08-13-2019 10:17
Subject: Selecting test cases based on their "priority" while adding a new test cycles
While adding a test cycle, I can select test cases by "test groups" and/or "test run status".
I also like to be able to select test cases based on their "priority" while adding a new test cycle.
i.e. Sanity test cycle would include priority 1 test cases from each test group while regression test cycle would include priority 1 & priority 2 test cases.
Ilkay Kucuk
Irdeto
