Add Color to Releases
It would be nice to be able to set the color for releases like you can set the color for pick list values. The default color for the "Unassigned" release is blue in the dashboard pie chart, and I would like to make it red so that requirements not assigned to a release are highlighted in a color that will draw attention. Also some of the colors chosen are not ideal - for example I am seeing 4 shades of blue which are harder to differentiate than if another color like purple was used. Finally, the release colors are not consistent across chart types. We have a bar chart of releases and another pie chart of a subset of requirements colored by release. The color for "Unassigned" in the bar chart is green, whereas in the pie chart it is blue (and the other releases are inconsistent as well). If I could set the color for releases, then we could customize to best meet our needs and hopefully be consistent across the entire dashboard.
LC
