Seeing the Test Case ID in the Test Run screen
would it be possible to add the Test Case ID to the fields that can be displayed as a column in the Test Runs page?
Currently the ID that is shown is the Test Run ID, but I would like to be able to see the Test Case ID related to the Test Run.
I can configure the view and add "Test Case", but then a hyperlink with the same text as "Name" is displayed. It would make much more sense having the Test Case ID instead, since we already have the Name field.
Ramiro
Ramiro
