Move function - after item being moved, the workflow rule should be from the destination project ins
Lien Bäcker
edited August 2019 in
this is about a Bug SOS-DEF-4014. As per Suggestion from our Account Manager, i would like to submit it as Feature request.
I move a set from the Source project to the Destination project.
A Workflow is implemented on Status.
The Workflow permission configurations are different between the Source project and the Destination project.
Source
Destination
After being moved from the Source project to the destination project, for all the being moved items, the Workflow applied is following the configuration in the source project. In this case, only the users are in the mentioned group in source project could change the status from "Analyse in Bearbeitung" to "(D4) Ursache erkannt". There is no way for Admin or users with manage project right in the destination project to get everyone to be able to change the status from "Analyse in Bearbeitung" to "(D4) Ursache erkannt" according to the configuration of the workflow in the destination project. We have tried with Workflow update, Project reindex but it does not resolve the issue.
The Move fuction is needed by our users. We need a solution to archive: once a set was moved from the source project to the destination project, the workflow rule from the destination project shall be applied to the moved items. The workflow rule applied to the moved items shall be no more from the source Project.
Lien Bäcker
