Add Items to Existing Review
+1 for this idea
------Original Message------
When we create a review by selecting individual items (as opposed to a folder, component, or set), it would be very helpful to able to add or remove requirements without closing the review and creating a new one. Obviously, we try to create reviews based on sets, components, etc whenever possible, but for some of our use-cases, individual item reviews are necessary. Somewhat regularly, review feedback may result in adding additional requirements. Right now, our workaround is to close out the current review and create a new one, however, this makes it so reviewers lose their existing approvals, comments, etc.0 -
We use tags and filters to get around this. By using tags, we can add new requirements then tag it. This will create a new version of the review vs having to start overElizabeth Rosenberg
Alight Solutions0 -
Agree with this, would be very useful. We have exactly the same workaround with exactly the same problem.0
+10This is a very common problem we run into.-Sven Schmidberger
I'd like to pile on another request.... we would like that items that are Associated with a Change Request would pull into a review without having to use tags /filters.Elizabeth Rosenberg
Alight Solutions0 -
To have the ability to create a review on items associating with a change request is exactly what we are currently looking for.
So + 1 from us0 -
Decoteau Wilkerson Jama Staff, Data Exchange, Moderator, Automotive Solution, Medical Devices & Life Sciences Solution, Robotics Solution, Airborne Systems, Jama Connect Interchange™ (JCI), Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 48OptionsHi all! I'm commenting on this thread to share a recently filed Ideation card geared toward this topic.
For those who are interested, please visit and vote/comment on this to share your feedback with our Product team:
Add Items To Existing Review - Ideation CardDecoteau Wilkerson
Content Marketing Specialist
Oregon0 -
+10
Cody, this is only a small part of your request, but removing items will be an option with 8.67.
