Login failures result in Exception
I noticed today after some troubleshooting that when a users tries to login with a wrong password this results in an exception that is being logged. We use LDAP authentication.
I would expect such an exception to be caught and logged only as a normal logfile entry.
As we are troubleshooting other problems those exceptions are disturbing, as real problems are "concealed" within those exceptions:
Thank you
2019-09-10 06:18:28,716 ERROR http-nio-8080-exec-20 vmjamadb [284f1d] [com.jamasoftware.contour.dao.LdapUserDao] - There was an exception getting the contextMaybe this could be fixed in future releases.
org.springframework.ldap.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090400, comment: AcceptSecurityContext error, data 52e, v1db1 ]; nested exception is javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090400, comment: AcceptSecurityContext error, data 52e, v1db1 ]
at org.springframework.ldap.support.LdapUtils.convertLdapException(LdapUtils.java:180)
at org.springframework.ldap.core.support.AbstractContextSource.createContext(AbstractContextSource.java:266)
at org.springframework.ldap.core.support.AbstractContextSource.getContext(AbstractContextSource.java:106)
at org.springframework.ldap.core.support.AbstractContextSource.getReadOnlyContext(AbstractContextSource.java:125)
at com.jamasoftware.contour.dao.ldap.LdapUserDaoImpl.authenticateUser(LdapUserDaoImpl.java:190)
at com.jamasoftware.contour.util.auth.LdapProviderManagerImpl.authenticateUser(LdapProviderManagerImpl.java:39)
at com.jamasoftware.contour.util.auth.TenantAwareLdapProviderManagerImpl.authenticateUser(TenantAwareLdapProviderManagerImpl.java:28)
at com.jamasoftware.contour.security.UserAuthenticator.authenticateLdapUser(UserAuthenticator.java:104)
at com.jamasoftware.contour.security.UserAuthenticator.authenticateUser(UserAuthenticator.java:61)
at com.jamasoftware.contour.service.impl.ContourUserDetailsService.loadUserByUsername(ContourUserDetailsService.java:46)
at jdk.internal.reflect.GeneratedMethodAccessor1146.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:333)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:99)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:282)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy350.loadUserByUsername(Unknown Source)
at com.jamasoftware.contour.security.ContourDaoAuthenticationProvider.retrieveUser(ContourDaoAuthenticationProvider.java:46)
at org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:144)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:174)
at com.jamasoftware.contour.security.ContourProviderManager.authenticate(ContourProviderManager.java:36)
at org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter.attemptAuthentication(UsernamePasswordAuthenticationFilter.java:94)
at com.jamasoftware.contour.security.ContourAuthenticationProcessingFilter.attemptAuthentication(ContourAuthenticationProcessingFilter.java:174)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212)
at com.jamasoftware.contour.security.ContourAuthenticationProcessingFilter.doFilter(ContourAuthenticationProcessingFilter.java:71)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at com.jamasoftware.contour.security.SecurityHeaderFilter.doFilter(SecurityHeaderFilter.java:29)
at com.jamasoftware.contour.security.saml.SamlEntryPointFilter.doFilter(SamlEntryPointFilter.java:29)
at com.jamasoftware.contour.view.filter.CSRFSecurityFilter.doFilter(CSRFSecurityFilter.java:58)
at com.jamasoftware.contour.view.filter.NosniffFilter.doFilter(NosniffFilter.java:17)
at com.jamasoftware.contour.view.filter.TenantSecurityContextFilter.doFilter(TenantSecurityContextFilter.java:43)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:134)
at com.jamasoftware.contour.view.filter.ContourConcurrentSessionFilter.doFilter(ContourConcurrentSessionFilter.java:40)
at org.springframework.web.filter.CorsFilter.doFilterInternal(CorsFilter.java:96)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at com.jamasoftware.contour.view.filter.TenantFilter.doFilter(TenantFilter.java:84)
at com.jamasoftware.contour.view.filter.NewRelicTransactionFilter.doFilter(NewRelicTransactionFilter.java:34)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at com.jamasoftware.contour.view.filter.GzipFilter.doFilter(GzipFilter.java:48)
at com.jamasoftware.contour.view.filter.Log4jFishTagFilter.doFilter(Log4jFishTagFilter.java:27)
at org.springframework.session.web.http.SessionRepositoryFilter.doFilterInternal(SessionRepositoryFilter.java:167)
at org.springframework.session.web.http.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:80)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:685)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:800)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:806)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1498)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090400, comment: AcceptSecurityContext error, data 52e, v1db1 ]
at java.naming/com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3158)
at java.naming/com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:3104)
at java.naming/com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2890)
at java.naming/com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2804)
at java.naming/com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:320)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:192)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:210)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:153)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:83)
at java.naming/javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:730)
at java.naming/javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:305)
at java.naming/javax.naming.InitialContext.init(InitialContext.java:236)
at java.naming/javax.naming.ldap.InitialLdapContext.<init>(InitialLdapContext.java:154)
at org.springframework.ldap.core.support.LdapContextSource.getDirContextInstance(LdapContextSource.java:43)
at org.springframework.ldap.core.support.AbstractContextSource.createContext(AbstractContextSource.java:254)
... 89 more
2019-09-10 06:18:28,718 INFO http-nio-8080-exec-20 vmjamadb [284f1d] [com.jamasoftware.contour.security.UserAuthenticator] - [LDAP] - The LDAP user credentials you entered were not valid, please try again.
Thank you
Anna:
Thank you for pin-pointing this for us! I am going to change this thread to a Product Idea to give it visibility to our Product teams when they work on this area.
Best,0
