Ideas, experiences and thoughts from user and admin point of view
We have collected some ideas, experiences and thoughts from user and admin point of view:
- When clicking on a requirement and following the relationships, there should be a configurable option that the requirements tree follows the displayed item (similar to the behavior of Eclipse where the file tree pane *can* follow the contents shown in the editor pane).
- Clicking on the dash board in the 'Relationship diagram' on an item type should allow to jump
- On double click on the first item in the tree (depending on sorting, e.g. alphabetically)
- On right click show selection of the present entries and allow selection of one
- The usage of the comment 'enter' field is inconsistent over the different views:
- View 'Projects': sub-view 'item': How to add clickable links?
- View 'Reviews': sub-view 'Feedback': persons/groups cannot be addressed with @Name in the case of someone has a question that the reviewer cannot answer
- Usage of review process: Where to click approve when a comment was sent? Full requirement is not displayed. Do we need to change the display options?
- Auto-transition requirement (with asking) when review was fully approved by all reviewers/approvers. How to do that?
- When using the trace view, how can we simply re-arrange the order of the displayed columns: We always need to de-select everything and then select the desired columns in the desired order?
- When creating a new item type it would be much faster if an existent one could be selected as a base for the new one
- Project Managers should be able to add people and change access rights for their projects, not only the admin. They should be more empowered in this regard like they are in the real life.
- When creating a new relationship diagram it would be much faster if an existent one could be selected as a base for the new one
- Undo buttons would be much appreciated for any actions done by the users and admins.
We are using version 8.25.3 of Jama Connect.
