All,
I have a use case where a test cycle that normally would be executed in Jama needs to be done the old fashioned way (on paper). I would like to export the cycle with each test case including the steps into a word doc for export. The user will then fill out the steps and results on paper and we will need to manually update the results.
Any Ideas?
Matt Kaiser
OSI
