I'm looking for a solution for an issue
A test plan was generated, 3 test cases (TC1, TC2, TC3) were added to a test group. The Test engineer generated test cycle, which have 3 test runs (TR1, TR2 and TR3) associated to the 3 test cases (TC1, Tc2 and TC3). Test engineer executed the test runs.
In some cases, there is a need to change the structure of the test plan even though the testing was already started. So a test case TC3 was removed from the test group in the test plan generated above. So we have a situation
Test plan contains TC1 and TC2.
In the generated Test cycle, we have TR1, TR2 and TR3. What can we do to remove the TR3 from the test cycle and to make sure that the test result of TR3 should not be considered for the test case status of TC3?
There is a constraint here also: delete an existing test cycle and create a new test cycle after the TC3 being removed is not an option since the time stamp of the test execution for TR1 and TR2 very important.
Thanks much in advanced for the solution info.
Lien Bäcker
