Product Idea
Hover tooltip in project explorer should contain item information instead item type
  • 1.  Hover tooltip in project explorer should contain item information instead item type
    Posted 10-28-2019 05:43
    Hover tooltip in project explorer view does not contain relevant information
    How to reproduce:
    1. Go to Jama 'PROJECTS' tab
    2. Hover mouse pointer above an item in project 'Explorer'
    Actual result:
    Tooltip contains item type, e.g. "Software Test Case"
    Wanted result:
    Tooltip contains item name, e.g. test case name
    Anja
    Finland
  • 2.  RE: Hover tooltip in project explorer should contain item information instead item type
    Posted 10-28-2019 13:22
    Anja:
    The "name" of the item should be listed directly in the Explorer. In my instance I hover over the "item name" to get the tooltip to show the item type. Is that not what you are seeing in your Explorer view? Do you have your view configured in some other way, perhaps a screen shot would help - if that is possible?
  • 3.  RE: Hover tooltip in project explorer should contain item information instead item type
    Posted 10-28-2019 23:24
    Attached an example when I hover over a "Software test case" item type. It shows the item type name instead of the item content name.  What i want to see here is "Verify CPUc Condition KPI DCVoltage.... "
    Item type name shown instead of item content name
    Anja
    Finland
  • 4.  RE: Hover tooltip in project explorer should contain item information instead item type
    Posted 01-06-2020 16:57
    Thanks for pointing this out, @Anja . I agree, I would expect the item's full name to show in the tooltip. We've updated this in our latest cloud release 8.45. ​​
    Robin Calhoun
    Product Manager
