Hallo,
"Make Test Run Current" will also occur in case the Test Run being locked.
I would like this to be changed.
I cannot set permissions in the Test Management area in order to limit the users performing a "Make Test Run Current" (Create/Edit User can perform it). -> see an older post from myself
An alternative would be the Project Administrator manually locking the Test Runs to be protected, but this is not working.
