Feature Requests
Review with Downstream / Upstream
  • 1.  Review with Downstream / Upstream
    Posted 11-05-2018 18:47
    Having links to downstream items in Review Center was a big help.  But we need an option to show the content of those downstream items, without having to click a link ( especially for at least one level downstream ) to really make the feature useful.
    Consider a not unusual case where you have an item type called Features, which has a downstream item called Requirements.
    It would not be unusual to have 2 or 3 dozen requirements attached to a single feature.  Approving the Feature is really about approving both the Feature and its Requirements.  Clicking through all of those requirements is not tenable, plus you can't highlight and comment on the text of those Requirements.
    If you include the Requirements in the review as another item type for review ( or do them separately in their own review ) then they are divorced from their parent Features, and impossible to understand out of context.
    If you don't break out Requirements as its own item type, but instead bundle them up as a list inside a field of Feature, then you lose the power of Jama's trace analysis.
    So ultimately, it would be great if review center could do a review like this:
    Feature1
    This is the description of Feature 1
    - Requirement 1
      - Feature 1 shall have widgets
    - Requirement 2
      - Feature 1 shall have knobs
    Alex E
    American Innovations
    Austin TX
  • 2.  RE: Review with Downstream / Upstream
    Posted 11-06-2018 08:49
    I strongly agree with this!
    ​We have a very similar use case.  In my mind, this is the single biggest shortcoming of Jama.
    Because of this shortcoming, we have had to design our business process around the tool limitations. This has caused a lot of user frustration.  After our pilot we had to entirely redesign our implementation, in large parts due to this limitation.
    Our current work-around for this limitation is to create a single review for each feature, and it's downstream requirements.  The unfortunate side effect is that the reviewers receive a VERY high number of reviews each sprint.  It also means that the teams have to create a very high number of reviews, which is inefficient.
    The benefit of this approach is that it focuses the reviewers attention on a single feature.
    Justin Sterkel
