Add item IDs and links to project pages in review center
Joao Simao
Member Posts: 3
When you look at items in the Review Center it shows the heading of the item instead of the item key (API ID), something like:
3.2.4.2.7.1.3 Item Title
Trying to find the corresponding item in the Projects tab is a pain. There is no item ID you can search for, you cannot search for the heading number, and you can only resort to searching for the whole item title in quotes, or trying to find your way through the project tree.
Clicking the title leads you to the individual item review page which we hardly use at all and only arrive there by accident; and only moderators can edit the item from there. We normally let approvers fix small typos in the code to avoid a overhead of comments, but for that they need to find the item in the Projects tab.
Could you consider adding a link to the project page, with the item ID, for each item in the review center? (I would actually prefer that it replaced the heading as we have no use for it either)
Using the web version, the fields that are shown in both the list and item views within the review centre are configurable. Settings can be changed from ADMIN/ITEM TYPE, select 'configure view' and then the view to change ('Review Centre Reading View' by the sounds of what you're after). Then add/remove fields as needed.0
