Restore function for deleted Test plan, test cycle and test run
Lien Bäcker
Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 84
We notice, Jama does not have any mechanism to prevent users' fehler from unintendedly deleting test plan, test cycle with all test results.
Unfortunately that exactly just happened to us. A Tester has just accidentially deleted a test cycle with critical test result.
We are looking for the way to restore this test cycle with the assossicated test result. Parallel I would like to submit a Feature request:
Jama shall provide the restore function to deleted test plan, test cycle as well as test run.
Additionally a possible System lock for test plan and test cycle would be great to prevent such unintented deletion of testing result data.
Hi all,
we have occasionally the same issue. My - only partial - solution is to baseline all that stuff.
About "make test run current" -> I have written a VTL report to show the content of all "involved" Test Runs : get Test Run -> get Test Case -> get all test Runs (deleted too). In such a way the user clicking by accident on "make test run current" can retrieve the deleted stuff (from field "actual result", e.g.).
Lien,
why don't you submit the feature request? I am going to "like it".
Best regards,Alessandro
SICK AG0
