New line is not supported in JAMA for updating a test step
I found a thread in the community regarding New lines from 2015 that I was wondering if this is has been discussed further and perhaps planned for an enhancement.
We are currently importing our test books through excel and regardless of having line breaks in the same cel for the Actions, Results or Notes, line breaks are ignored and information is pulled together (concatenated) in the test runs. However, new lines do appear when in edit mode in JAMA after importing, but just not displayed on the test run. The issue with this is that when the test cases require a lot of information, it is hard for the tester to follow.
At the beginning I thought this was a bug since I could see it while in edit mode, but it seems it is not as it is behaving the same since 2015. Is this something that has been discussed in the past and perhaps planned for an enhancement?
Lilliana
Lilliana
