Product Idea
Reading View Refresh
  • 1.  Reading View Refresh
    Posted 04-12-2019 14:06
    In JAMA Connect -> Requirements -> Reading View, after commenting on a requirement, the page refreshes and goes back to the top of the page, requiring to scroll down to the page every time.
    As a <g class="gr_ gr_643 gr-alert gr_gramm gr_inline_cards gr_run_anim Punctuation only-ins replaceWithoutSep" id="643" data-gr-id="643">user</g> while I would like to get my comments reflected on the requirement, I would also like to be on the same page instance. It's irritating to keep scrolling down to the last reviewed requirement as the page keeps going back to the top of the page.
    Rahul
    Rahul Khurana
    Sr. Systems Engineer
    NeuroStar Inc.
    PA
    6109814122
  • 2.  RE: Reading View Refresh
    Posted 04-12-2019 14:07
    Now when I think about it, this probably shouldn't be a new feature but correct implementation to the current functionality.
    Rahul Khurana
    NeuroStar Inc.
    PA
    6109814122
  • 3.  RE: Reading View Refresh
    Posted 06-09-2019 11:48
    Agreed, there are actually several instances where Jama refreshes in ways that make using the tool a chore at times:
    1. Every time you move an item in the explorer window, the explorer window refreshes, collapsing every single container you had open except for the container the item moved to.
    2. Every time you open a new Jama tab from search results, Jama recalculates the search results and removes all filters previously applied. This one is particularly irritating because it wastes time recalculating the results in addition to having to re-select several filter choices.
    Using Jama Home Instance 8.33.1.
    Jason Soares
    Viasat
  • 4.  RE: Reading View Refresh
    Posted 06-10-2019 05:28
    Additional place: reusing an item collapses explorer.
    Workaround for the search issue, but also a nuisance: create a filter if the search is one that you use frequently, i.e., I have a filter that shows my FRS that are in Review state. Otherwise, I keep having to redo the search.
    Cynthia Weber
    Business Systems Analyst Lead
    ProQuest LLC
    Ann Arbor, MI
  • 5.  RE: Reading View Refresh
    Posted 06-10-2019 05:56
    It would be great to see some improvement in this area.
    Robena Sukhu
    Sun Life Financial
    ON
    416-496-5456
  • 6.  RE: Reading View Refresh
    Posted 06-10-2019 10:44
    +1
    Jonah Caplan
