Product Idea
Enable repeats of tests in a testcase
  • 1.  Enable repeats of tests in a testcase
    Posted 07-31-2018 02:22
    For reliability purpose we use so called parameter tests between reliability test for checking the modules on functionality. To 'drag' 1 test several times in a testcase is impossible hence we can not create the test-plan as we currently use within Excel.
    Excel layout (example):
    see attached image: Capture1.PNG
    Trying to create this testcase within JAMA will result into the following error/message:
    see attached image: Capture2.PNG
    Can JAMA enable multiple selection, or provide different workaround (without creating multiple version for the parameter test)
    Marcel Bachus
    Innolux Technology Europe B.V
  • 2.  RE: Enable repeats of tests in a testcase
    Posted 08-01-2018 16:38
    Hi Marcel -
    I am interested in your post because I think we might have a similar issue. However, I can't view/open the images you pasted into your post. Could you attach the image files to your post? I believe you should be able to edit your existing post.
    Theresa
    Fujifilm SonoSite
    WA
  • 3.  RE: Enable repeats of tests in a testcase
    Posted 08-01-2018 22:44
    Hello Theresa,
    Please find attached the 2 pictures.
    Marcel Bachus
  • 4.  RE: Enable repeats of tests in a testcase
    Posted 08-02-2018 15:59
    Hi Marcel -
    Thank you for attaching those files. We discussed a similar situation with our Jama consultant earlier this week. If no one else responds to your question, I can share what we learned. We are new to Jama so I don't want to add to your challenge by providing incomplete or incorrect information.
    Best Regards,
    Theresa
    Fujifilm SonoSite
    WA United States
