Rich Field for Actual Results in Test Run
Simon Meng
Member Posts: 3
Hi Everyone,
It seems that JAMA does not support the rich field for the actual results column in the test run but able to support the rich field for the expected results in the test cases.
I need to attach tons of screenshots from oscilloscope for most of the test steps during the test run.
Does anyone have a good suggestion on a workaround? I know we can attach each figure in the actual results description sections. But it seems hard to manage the screenshot. The other way I can think of it is to attach an attachment. But then I need to insert all the figures into a word and then attached it for each test run. Not sure if how to export all together then.
Does anyone know if JAMA is going to support this feature soon?
Simon
