Folder-based relationships
Use case: Folder created in the verification tests section that is related to a specific requirement (e.g., "Alarm Settings" requirement is related to the "Alarm Settings" folder within the verification tests set). When tests are created in that folder, the tests automatically inherit the relationship to the requirement the folder is mapped to. The folder relationship isn't displayed or traceable, only the items within the folders.
Thanks.
This would be very useful as some of the requirements have over 500 test cases since we write them to only cover a small item.0
I am surprised this has not gained traction. If someone adds two new items to a folder and fails to add the relationship to two other needed items (2x2 = 4 individual relationships to create), the integrity of the entire system and 'coverage' analysis is impacted. This can all be avoided with a special folder type that permits realtionships to that type of folder.
Marc Ford
GM / Brightdrop
Sent: 03-21-2019 05:06
Subject: Folder-based relationships
Cynthia Weber
Business Systems Analyst Lead
ProQuest LLC
Ann Arbor, MI
Sent: 03-20-2019 07:57
When adding a relationship, allow to select at the folder level (and then apply that relationship to all items within the folder).
Thanks.
Nicki Repici
ZOLL
Pittsburgh PA
------------------------------0 -
I also think this would be helpful. I have posted some time ago also an idea for Jama to allow relationships to a folder: Add a relationship to a Folder
Iwan Kutter
Requirement Engineer
Sent: 08-28-2023 12:00
Subject: Folder-based relationshipsI am surprised this has not gained traction. If someone adds two new items to a folder and fails to add the relationship to two other needed items (2x2 = 4 individual relationships to create), the integrity of the entire system and 'coverage' analysis is impacted. This can all be avoided with a special folder type that permits realtionships to that type of folder.
Marc Ford
GM / Brightdrop
Cynthia Weber
ProQuest LLC
Ann Arbor, MI
Thanks.
Nicki Repici
ZOLL
Pittsburgh PA
------------------------------Iwan Kutter
Bernina International0 -
I also think it would be helpful to be able to add items to a folder and have the relationships to that folder be applied to all items in that folder.
Chris Freitag
Manager, Hardware Engineering
MKS Instruments, Inc.
This message and any attachments are intended only for the designated recipient(s) and may contain confidential or proprietary information and be subject to the attorney-client privilege or other confidentiality protections. If you are not a designated recipient, you may not review, use, copy or distribute this message or any attachments. If you received this email in error, please notify the sender by reply e-mail and permanently delete the original and any copies of this message and any attachments thereto. Thank you.
Sent: 8/29/2023 2:06:00 AM
Subject: RE: Folder-based relationshipsI also think this would be helpful. I have posted some time ago also an idea for Jama to allow relationships to a folder: Add a relationship to a Folder
Iwan Kutter
Marc Ford
GM / Brightdrop
Cynthia Weber
ProQuest LLC
Ann Arbor, MI
Thanks.
Nicki Repici
ZOLL
Pittsburgh PA
