Feature Requests
Feature Request: Review Status Workflow shall work on the Status even when Status was controlled by Workflow function
  • 1.  Feature Request: Review Status Workflow shall work on the Status even when Status was controlled by Workflow function
    Posted 11-30-2018 03:51
    Review Center and Status Workflow are both our favourite functions of Jama.
    We make use of Review Center for the approval process.
    We make use of Status Workflow to make sure the work are confront to the business process.
    But currently, the Status Review Status Workflow – if review is finalized, set Status to approved – does not work on Status, which is under control from Status Workflow. So there are manual work, we need to finalize the review, than someone would need to manually Batch Transition on Status to bring from "for approval" to "approved" and create a baseline, get all the stakeholder to sign on the baseline. Right now, the structure under baseline tab is a mess and there is no way to make any connection between the finalized review and the baseline with those requirement with "approved" status.
    Those extra work could be saved if Jama could implement this Feature request:
    Review Status Workflow shall work on Status (with or without the controlling of Status Workflow) – if a review is finalized, status of all items under review will be set to "approved" – like what we can configure now.
    And Jama generate a new baseline with the digital signatures from the finalized review and the content of the review + status = "approved", which was updated on the step before.
    Lien
    GIRA
