Revert possibility to set test run status for all step via the last check button
Hello this is a comment from our users:
With the recent changes to the presentation of Contour test run execution, Is it possible to revert to the old operation of selecting the last check button, which automatically fills the entire table ?
For example, if I check the Pass Check icon, Contour automatically fills the previous steps with the Pass check icon.
Thank you
Thanks Vlada:
We are currently researching in the Test Center area of Jama, I would like to invite you to do this Test Center Interest survey.
Best,0 -
Hello Chloe,
Filled in. Nevertheless, I'm not sure how the survey is related to the required change (revert).
Vlada0 -
When can we expect that the functionality is back?Vlada0
Hi Vlada,
I'm not running v8.48 but according to the release note: "You can now select multiple steps when executing a Test Run. "
So I guess that you can workaround the loss of autocomplete by first selecting all steps; let us know.
FYI, other users are delighted with the auto-fill disabling (see https://community.jamasoftware.com/communities/community-home/digestviewer/viewthread?MessageKey=529a7003-ec08-43f0-9eda-22cb6f19c441&CommunityKey=c9d20d4c-5bb6-4f19-92eb-e7cee0942d51&tab=digestviewer#bm529a7003-ec08-43f0-9eda-22cb6f19c441)
Still, I do agree that this behavior could have been subject to customization.
See my post, number 9: "... My proposal is then to add an option in the Test Case configuration to enabling/disabling the step auto fill. It would also be great to be able to customize the Step field name and related table headers."
0 -
Hello Christian & Thank you for your message.
Yes, I'm waiting for deployment of 8.48 later today to check if it this feature can be a workaround.
Nevertheless, I haven't read in release notes about change in the functionality. Also. I'm surprised that Jama hasn't commented this post.
Of course I agree with configuration option for this functionality and understand that it can be a problem for some users. For us it was a benefit.
Have a nice day & Take careVlada0 -
Vlada, thank you for your feedback. You may have seen that from 9.5 forward, Organization Administrators have the ability to configure how the system will behave when users skip test steps and don't assign them a status:
Assign "Passed" to all skipped steps
Do not assign status to any skipped steps
Allow tester to select status for skipped step (i.e. ignore, pass, fail)
Ashley Ernst
CA
Sent: 03-13-2020 03:56
Subject: Revert possibility to set test run status for all step via the last check button
Vlada
Sent: 03-13-2020 06:16
Hi Vlada,
Christian Binard
ON semiconductor
Belgium
Sent: 03-12-2020 05:32
Vlada
Sent: 02-21-2020 01:47
Subject: Revert possibility to set test run status for all step via the last check buttonHello Chloe,
Vlada
Sent: 02-20-2020 09:46
Thanks Vlada:
Sent: 02-20-2020 09:25
Subject: Revert possibility to set test run status for all step via the last check buttonHello this is a comment from our users:
With the recent changes to the presentation of Contour test run execution, Is it possible to revert to the old operation of selecting the last check button, which automatically fills the entire table ?For example, if I check the Pass Check icon, Contour automatically fills the previous steps with the Pass check icon.
Thank you
Vlada
Ashley Ernst
[Pronouns]
Product Manager
Jama Software0 -
Instructions:
- Navigate to Admin > Organization Admin > Item types
- Select the Test Run item type in the left panel
- Select the Status field in the right panel and click the pencil icon to edit
- From the popup window, select the desired default behavior for completing steps out of order
- Click save
Ashley Ernst
CA
Sent: 11-30-2023 12:03
Subject: Revert possibility to set test run status for all step via the last check buttonVlada, thank you for your feedback. You may have seen that from 9.5 forward, Organization Administrators have the ability to configure how the system will behave when users skip test steps and don't assign them a status:
Ashley Ernst
CA
Vlada
Hi Vlada,
Christian Binard
ON semiconductor
Belgium
Vlada
Vlada
Thanks Vlada:
Thank you
Vlada
Ashley Ernst
[Pronouns]
Product Manager
Jama Software0 -
Hello Ashley,
Please be so kind and show me when the Status field for the Test Run is presented. See the attached picture. I cannot see the Status for the Test Run there.
And by the way. The come with the solution more than 3 years after the issue was introduced by Jama is 21 century customer oriented approach. Happy that we are decommissioning Jama.
Thank you
Vlada
Vlada
Sent: 11-30-2023 12:24
Subject: Revert possibility to set test run status for all step via the last check buttonInstructions:
- Click save
Ashley Ernst
CA
Ashley Ernst
CA
Vlada
Hi Vlada,
Christian Binard
ON semiconductor
Belgium
Vlada
Vlada
Thanks Vlada:
Thank you
Vlada
Vlada0 -
Hello Vlada,
It appears 'Status' has been renamed to 'Verdict' in your configuration. You can look for "testRunStatus" in the Unique Field Name column and click the pencil icon when that row is selected.We wish you the best of luck in your future endeavors.
Jeremy Johnson
Sent: 12-03-2023 22:21
Subject: Revert possibility to set test run status for all step via the last check buttonHello Ashley,
Thank you
Vlada
Vlada
- Click save
Ashley Ernst
CA
Ashley Ernst
CA
Vlada
Hi Vlada,
Christian Binard
ON semiconductor
Belgium
Vlada
Vlada
Thanks Vlada:
Thank you
Vlada
0 -
Thank you Jeremy.
It works.
Vlada
Sent: 12-05-2023 12:42
Subject: Revert possibility to set test run status for all step via the last check buttonHello Vlada,
Jeremy Johnson
Thank you
Vlada
Vlada
- Click save
Ashley Ernst
CA
Ashley Ernst
CA
Vlada
Hi Vlada,
Christian Binard
ON semiconductor
Belgium
Vlada
Vlada
Thanks Vlada:
Thank you
Vlada
Vlada0
