Customize Execution View
Luigi Salce
Luigi Salce Member, Data Exchange Posts: 7
I've got some user's that would like to see a certain field in the Test Execution view of a Test Run.
As of right now, I dont see any way to add in the requested field to this view. The user does not want to have to select the "Test Case" tab in order to view this information. It would be great to have the ability to customize the Test Execution view.
    I would also like to submit this request. It would be good to be able to rearrange at least the fields already in the text execution window. For example, we would like to move "description" above the execution steps so the testers don't have to scroll down to keep checking the description while executing their tests.
    [Deleted User] Posts: 6
    edited June 2019
    I also agree with this. There doesn't seem to be any response from JAMA on this. We've added a custom field to test runs but its only visible AFTER executing a test, which is very clunky.
