Reuse item(s) - "Add a relationship from the original item" - Cannot choose relation type
Uwe Matzen
Uwe Matzen Member, Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 8
edited November 2019 in
In the "Reuse item(s)" dialog, if one were to activate "Add a relationship from the original item", it would make sense if the user could choose the relationship type. Right now it forces you to accept the Default, which is  "Relates to".
In our case, the set of item to re-used are part of a template, and we have a relationship type called "Based on template", but we aren't given the option to select it for re-used items.
