There is a workaround! If you're using the draw.io web app or program on your computer, click 'Extras/Edit Diagram'
Then copy the xml in the jama editor. It's an older and/or restricted version of draw.io, so it's under 'File/Edit File'
Not sure why cut/paste from one to the other doesn't work. When you cut/paste between drawio you're just copying and pasting xml under the hood. Something a bit funky is happening with the draw.io integration in Jama to break this feature.
Jonah Caplan
QNX
Sent: 03-22-2017 21:55
Subject: Round Trip for Diagrams
Jama's in-built diagram editor looks very similar to draw.io. I presume you are using the same draw.io libraries.
However, we find that there is no way to import or export diagrams to/from the Jama diagram editor (unlike draw.io which can import/export in the standard SVG format). That limits its utility. For instance, we cannot export the diagrams and have other tools operate on them and re-import them into Jama. Can we request Jama to add the SVG import/export functionality to the diagram editor? My guess is that SVG import/export in Jama is going to be easy to implement because the draw.io library should already have the required support built in.
Thank you!
Devang Sanghrajka
