Add Test Case ID as Possible Column for Test Run View
When configuring the view for Test Runs, we would like to see Test Case ID become a possible column to select. There are times where the test case name is not unique enough when comparing test runs. The test case ID would give us a unique id within the test run as well as a way to match test cases across test runs.
Select Test Case, then you get the test case id as hyperlink.0
When comparing two test runs side-by-side hyperlinks will not help us. We need to be able to move down the list quickly, so we need the ID to be visible.0
