Filter Test Cases that are NOT part of a test plan
Ken G
Member Posts: 17
Is there a way from the Explorer Tab to filter on all test cases that are NOT associated with an existing test plan?
Regards,
Ken
Regards,
Ken
Ken G
Hi Ken,
There is no easy way to do this, so this is another thing we'd have to consider as a feature request. What's the purpose of needing this-is it to ensure that you have the proper test coverage?0 -
Correct. As part of the trace analysis / trace matrix audit, QA confirms each requirement is covered by at least (1) test case, AND all test plans (within a project) include at least one instance of every test case. e.g. it is OK for (2) test plans to include the same test case, it is NOT OK for a test case to be orphaned from a test plan.Ken G0
