Product Idea
Ability to do something and return to same spot
  • 1.  Ability to do something and return to same spot
    Posted 06-13-2018 04:47
    There are some places where, when I perform an action, I lose where I am currently. Some examples:
    1. Assigning test cases: select a group of unassigned test cases and assign them. You are returned to the top of the page, not where you were in the list.
    2. Execute a test case: our style is to have a lot of tiny test cases, so we are dealing with a test plan with over 1k of test cases. If I scroll down to find the next test case I am going to run, execute it, I am returned to the top of the page. Since, when you sort status, unexecuted test cases are not at the top, but after blocked/failed/in progress, you must scroll down after running each test case.
    3. Reuse a test case: after reusing a test case, I have to use the Find Me function to get back to where I was in the tree structure.
    If I could get returned to where I was, it would be a great time saver.
    Cynthia Weber
    Software Test Lead
    ProQuest LLC
    Ann Arbor, MI
